Old 01-27-2019, 07:58 AM   #1
kenparker
kenparker's Avatar
Default Varnish? on Huckster
What kind of finish do you Huckster owners put on the woodwork? Varnish? Spar Varnish? polyurethane? Urethane? Clearcoat? Oil rubbed?
etc? On initial coating and preservation and refreshing?
Some of the wood on my Special Delivery project is cut, sanded, drilled notched and is need of preservatoin before assembly. kenp
kenparker is offline   Reply With Quote
Old 01-27-2019, 05:58 PM   #2
Fred K-OR
Fred K-OR's Avatar
Default Re: Varnish? on Huckster
I have one of the Lentville A'S body on my huckster. It came with a finish already on it. But each year I try to put a coat of Armstrong "shine keeper" floor finish. This keeps the moisture from getting into the red oak. It is a clear type of coating. If I do it every year, it does a fair job of keeping the oak from turning black in spots.
Fred Kroon
1929 Std Coupe
1929 Huckster
Fred K-OR is offline   Reply With Quote
Old 01-27-2019, 06:04 PM   #3
30 Closed Cab PU
Not sure what you would use on a Huckster, but I use good quality Spar Varnish on my truck bed, holds up extremely well if not parked outside all summer, for years.
30 Closed Cab PU is offline   Reply With Quote
Old 01-28-2019, 01:33 AM   #4
redmodelt
redmodelt's Avatar
Mix in this link are some good idea;
https://www.modeltfordclubofamerica.....php?f=2&t=472
Old 01-28-2019, 07:53 AM   #5
desotoguy
Any finish that is exposed to the sun needs to have "SPAR" in the name. Plain varnish or other finish has no UV protection. Automotive clear coat can be applied to wood. It can be sanded and buffed to a high shine if that is what you want.
desotoguy is offline   Reply With Quote
Old 01-28-2019, 09:02 AM   #6
30 Closed Cab PU
Thanks for the link. How timely for me. The bed on my truck held up great for 5 years, until I had to leave it parked outside all last summer. Finish peeled, wood got moldy and gray, just as described in this link. A light minimal pressure, pressure wash, removed the mold and freshened the wood some. Will have to remove the wood, bleach/water the wood to kill any mold remnants, minimally plane it, and refinish. The last post in the string is excellent, need to thin down oil based coating so it will absorb instead of only coat.
