Old 08-16-2018, 11:38 PM   #1
Racur96
Racur96's Avatar
Default Original ammeter or repop?
Hi everyone. Got a ammeter in the original ford box just curious if it’s a original or repop unit .
File Type: jpg F76AE822-F179-40AE-ABE0-339A4881296A.jpg (42.6 KB, 207 views)
File Type: jpg 8437BB51-59DD-4317-BC19-7FBC48521667.jpg (40.5 KB, 184 views)
Racur96 is offline   Reply With Quote
Old 08-17-2018, 12:25 AM   #2
RandyinUtah
Default Re: Original ammeter or repop?
Looks like a nos for a truck . I have one like it myself and was told it was used in trucks but not positive. Check the judging standard for sure.
RandyinUtah is offline   Reply With Quote
Old 08-17-2018, 03:18 AM   #3
Mike V. Florida
Mike V. Florida's Avatar
I don't have the guidelines in front of me but I thing it's for a T.
Old 08-17-2018, 07:26 AM   #4
Mike Peters
Mike Peters's Avatar
JS sez "bezel is nickel plated brass". Scratch the back of the bezel to see if it's brass. I have one just like yours and have always thought it was an original, but like stated above, not for cars. T??? Good question.
Mike Peters is offline   Reply With Quote
Old 08-17-2018, 07:43 AM   #5
daren007
Open it up. The original should have a horseshoe round wire thing. If a re pop lay it on your driveway and run over it.
daren007 is offline   Reply With Quote
Old 08-17-2018, 07:57 AM   #6
MikeK
MikeK's Avatar
Original late T. Will work in an A but you either have to reverse the wires or open it and flip the magnet over. The magnet is the large steel wire shaped like a giant C clip inside the case.
MikeK is offline   Reply With Quote
Old 08-17-2018, 09:38 AM   #7
d.j. moordigian
d.j. moordigian's Avatar
That's an A...more than likely after the A's were produced. The bezel on the T's were
flat and didn't have the raised section on it..
d.j. moordigian is offline   Reply With Quote
Old 08-17-2018, 09:46 AM   #8
Kurt in NJ
Kurt in NJ's Avatar
post a picture of the box ----the design, printing can give clues to the era too
Old 08-17-2018, 10:12 AM   #9
Jeff/Illinois
Jeff/Illinois's Avatar
I like that
Some time back I bought an original ammeter that the late Doc Kalinka had restored from a fellow in Missouri. What a difference between that and the 70's repop that was in the car. It's great!
There had been some talk about someone reproducing the ammeters to original factory specs. I think that would be a good move and well worth the extra money over the off shore junk that is offered today. I see a need for a good, A&L quality-type ammeter.
Jeff/Illinois is offline   Reply With Quote
Old 08-17-2018, 10:15 AM   #10
P.S.
Looking through the glass, as grainy as the photo is when zoomed in, appears to be repro. Need pic of inside to tell for sure.
Looking at the back in your photo, the insulator washers scream repro.
P.S. is offline   Reply With Quote
Old 08-17-2018, 10:41 AM   #11
d.j. moordigian
Look were the "20" is placed !...then look at a known repop..
Old 08-17-2018, 11:54 AM   #12
Gary Karr
Gary Karr's Avatar
What you have is an NOS Ford replacement ammeter. It should work well for you. Simply remove the black painted bezel and have it nickel plated.
Gary Karr is offline   Reply With Quote
Old 08-17-2018, 12:56 PM   #13
Russ/40
Russ/40's Avatar
I thought the "T" meter was larger than the "A".
Russ/40 is offline   Reply With Quote
Old 08-17-2018, 01:46 PM   #14
Bob C
1926-27 used the small one.
Bob
Old 08-18-2018, 12:27 AM   #15
Drive Shaft Dave
I bought one of those on flea bay a few years back, had the bezel nickle plated.
Drive Shaft Dave is offline   Reply With Quote
Thread Tools
Display Modes
