03-11-2018, 07:38 AM | #1 |
powered by propane or cng
A bunch of years ago a fellow attended Texas Tour with a Model A pickup powered by propane and that intrigued me.
I would like to copy that and try to run one of my A's on either propane or CNG. Yes, I know you get less HP out of the propane or CNG, but I want to try anyway. Anyone out ther tried it or running your A on either? Any info ? kenp What triggered my reinterest was passing yesterday on the way home two taxicabs "powered by CNG". |
03-11-2018, 07:49 AM | #2 |
Re: powered by propane or cng
Check your messags
Brian SATX |
03-11-2018, 09:01 AM | #3 |
The USFS is using dual fuel F-150 pickups. I had a Bobcat that used propane and gas. Always had to switch over to gas when I needed more power.
No restorable Model A's were harmed in the building of this truck! |
03-11-2018, 04:55 PM | #4 |
There used to be LOTS of cars running on LPG here (propane) because it about halved the fuel bill (remember, we pay lots more for fuel than you guys). The price of gas has been rising since it was privatised until now, it is not much cheaper than petrol (when we say "gas", we mean "GAS", that's why the liquid fuel is called "petrol" - to avoid confusion.)
I have had several cars running on gas but the current one will be the last. To get the best out of LPG, you need a higher compression ratio so the ultra low Model A CR won't allow you to burn much rubber . Then there is the problem of where to put the tank. OK in say, a pickup but a roadster, coupe or sedan would be a challenge.
03-11-2018, 05:04 PM | #5 |
Find an updraft carb off of an old LP forklift and fit it to the A manifold. Or buy new, here is a source: https://www.propanecarbs.com/wisconsin.html
03-12-2018, 11:45 AM | #6 |
03-12-2018, 12:31 PM | #7 | |
You are going to be called a 'non-conformist' ..ha ! It costs $ to experiment, you may realize that. And, one of the higher cost with lower return is cost of propane these days ! There is a 'silver lining' , IMO, the propane burns very clean with less stuff left in your engine. |
