01-31-2017, 10:15 AM | #1 |
8 Volt battery
I was given an 8 volt battery by my local starter/genarator repair shop because my starter is hanging up sometimes on my A.
He said they hang up a lot of times because of lack of power so he said try the 8 volt battery and let him know. What do you guys know about this? My car is still running the stock 6 V system with the cut out switch on the generator. Thanks.
Isaiah B. 1928 all metal Tudor |
01-31-2017, 10:34 AM | #2 |
Re: 8 Volt battery
My car is running on 6 volt and the starter is never hanging up,must be a problem with the startermotor,not the battery
It is a pile of shit bit it's my pile of shit |
01-31-2017, 10:37 AM | #3 |
Re: 8 Volt battery
Sounds like a bad ground to me. How 'bout too small gage battery cables?
Just thinking out loud. . . . . Dick |
01-31-2017, 10:41 AM | #4 |
Re: 8 Volt battery
All the cables are original size but I have never had my engine loose to clean the grounds or anything like that so that might be the case. Both the ground strap to the negative side of the battery and the cable from the starter to the positive side of the battery are new and the complete harness from the starter to the generator are new as well. All factory looking and sized wires.
I was just wondering if any of you guys run an 8 V battery on your car to give it just a little bit more power?
01-31-2017, 10:49 AM | #5 |
Re: 8 Volt battery
When you say it hangs up?
Does it stick in the flywheel and not return or are you having a slow or no crank issue. More info needed |
01-31-2017, 10:51 AM | #6 |
Re: 8 Volt battery
01-31-2017, 11:01 AM | #7 |
Re: 8 Volt battery
8 volts will not help that problem. Many years ago in my Dad's garage we use to work on tractors. Some of the people had put 8 volt batters in to try and fix the real problem. They are more problems with a 8 volt than fixing the real problem. Could be a bent starter shaft, bad starter drive, bad flywheel ring gear.
01-31-2017, 11:35 AM | #8 |
Re: 8 Volt battery
Using an 8 Volt battery is like using a higher volt battery in your CLOCK--LOL
Bill W.
01-31-2017, 11:51 AM | #9 | |
Re: 8 Volt battery
Probably has nothing at all to do with the starter hanging up, however.
01-31-2017, 11:55 AM | #10 |
Re: 8 Volt battery
Your stock generator will fail quickly with 8v. I would not use it.
01-31-2017, 11:55 AM | #11 | |
Re: 8 Volt battery
01-31-2017, 12:35 PM | #12 |
Re: 8 Volt battery
I didn't know the existance of 8v batteries.
01-31-2017, 12:37 PM | #13 |
Re: 8 Volt battery
My starter has not jammed since replacing the ring gear, 2worn spots on the old gear
01-31-2017, 12:41 PM | #14 | |
Re: 8 Volt battery
I replaced with a proper 6v battery - never had another electrical related problem for the next 3 years I owned the roadster.
If at first you don't succeed, skydiving isn't for you! You don't need a parachute to skydive, you only need a parachute to skydive twice. |
01-31-2017, 12:52 PM | #15 |
Re: 8 Volt battery
Like others, I also suspect a ground problem. Try running a heavy gauge wire from the battery frame connection to one of the bell housing bolts near the starter. My starter would hang up occasionally until I did this. 40 year old riveted frame joints could offer a couple ohms of resistance and that is all it takes.
AL in NY |
01-31-2017, 01:54 PM | #16 |
Re: 8 Volt battery
If you want to be able to run faster, you double the voltage of your pacemaker.
Do as George said, fix the real problem. BTW, usually a jammed starter drive can be freed up by putting the car in high gear and rocking it back and forth. The forward motion should spin the drive rearward, back out of engagement. The best use for an 8 volt battery is to send me 4 of them, so I have 32 volts for my 32 volt Delco Light Plant. |
01-31-2017, 02:23 PM | #17 |
Re: 8 Volt battery
They work and have worked for years, as a bandaid for other problems. If the shop is actually saying that on the bench the starter hangs and needs 8 volts to work, in my opinion find another shop.
01-31-2017, 02:30 PM | #18 |
Re: 8 Volt battery
Yes, like Mike said, I was really surprised that any shop would suggest such a thing rather than fixing the real problem.
As mentioned, check the teeth of the pinion, and ring gear, and check the armature shaft to be sure it isn't bent. |
01-31-2017, 02:37 PM | #19 |
Re: 8 Volt battery
Ask around (maybe a local club) and find a shop that knows how to work on 6 volt cars. Fix the problem, don't just cover it up and cause other problems.
Charlie Stephens Last edited by Charlie Stephens; 01-31-2017 at 04:07 PM. |
01-31-2017, 02:56 PM | #20 |
Re: 8 Volt battery
Must agree with said here as we experienced the same issues with an 8 volt in a 30' P/U.
8 volt has been used in marine applications and six volt bulbs/generators do not like them. Until we replaced and cleaned the starter wiring, and installed a new 6 Volt, we had more problems than just a slow starter. Check to see the face of the starter and the starter mount are clean and paint/rust free as well. Good luck! |
