01-22-2017, 10:32 PM | #1 |
Put my seats back in today.
Put my seats back in the car today for the show next weekend.
Isaiah B. 1928 all metal Tudor |
01-22-2017, 10:34 PM | #2 |
Re: Put my seats back in today.
Got the seats in and brakes on,went to take it for a drive and now it won't run..
Ha ha oh well I checked everything except the carb so I'll pull it off tomorrow.
01-22-2017, 10:40 PM | #3 |
At least you have warm weather to work in.
Pillow cases make good seat back covers for your bucket seats. |
01-23-2017, 07:36 AM | #4 |
Im not saying this is at fault, but remember what we said about using the wireless lower plate.. keep us posted on this issue
01-23-2017, 08:19 AM | #5 |
Tom I never thought of that thank you! Ha ha
01-23-2017, 08:21 AM | #6 |
01-23-2017, 08:23 AM | #7 |
The car has been running perfect with clean spark plugs for the past two weeks with no problems and all of a sudden I get in it yesterday and it will barely run? I checked the timing and it was still dead on and then we timed it just in case and still the same.
01-23-2017, 08:24 AM | #8 |
Sorry to get off topic by the way.
01-23-2017, 08:26 AM | #9 |
I think I still have an old-style lower plate sitting around. Maybe I'll put that on tonight?
01-23-2017, 08:52 AM | #10 |
Make sure the wire is good... if not they sell them, special multi stranded
Once u got that going it wil be good for 80 years |
01-23-2017, 08:53 AM | #11 |
Thanks Mitch I'll check it out after work today!
01-23-2017, 10:58 AM | #12 |
I agree that the original style lower plate with a good 100+ strand wire is the best.
Be sure the flag terminal on the points nut is bend up along side the nut, so it doesn't short to ground. I had a distributor that would short to ground at certain positions of the spark lever. Once the terminal was bent up against the nut, there were no more shorts. |
01-23-2017, 11:00 AM | #13 |
I think Tom may have a good picture saved of the wire / terminal
01-23-2017, 12:18 PM | #14 |
Here's pictures in #9 and #16 Thanks to Marco and Dan.
http://www.fordbarn.com/forum/showth...wer+wire+marco |
01-23-2017, 01:30 PM | #15 | |
01-23-2017, 08:14 PM | #16 |
I am sure you will figure it out I really hope you enjoy the ride and I am positive your cheeks will hurt from your smile as you motor down the road
01-23-2017, 09:09 PM | #17 | |
6 Volt Dad (+ground)
01-23-2017, 09:47 PM | #18 |
Location: Barren windswept mountain somewhere in bleak Northeastern Pennsylvania
Actually . . . those Tudor front seats are comfortable. Just trying to figure a way, short of spot welding the thing, to not have the passenger side seat back flop forward at every stop sign. Don't recall any other of the Tudor sedans having this situation. Maybe a hose clamp might work?
I wouldn't be so paranoid if people weren't plotting against me all the time |
01-24-2017, 02:12 AM | #19 | |
I've never seen that problem, but am guessing the hinges are a bit worn. |
