Old 04-26-2016, 11:57 AM   #1
John Duden
John Duden's Avatar
Default French Gray Pinstriping
Where do find french gray pinstriping paint? i cannot find it through one shot
john
John Duden is offline   Reply With Quote
Old 04-26-2016, 12:16 PM   #2
Tiny
Tiny's Avatar
Default Re: French Gray Pinstriping
You might need to mix the proper french gray from several different colors. Most old time pinstriper's I know mix the correct color on their pallet. My guess would be grey + a dab of blue
Blackwall Panthers
Nor Cal chapter
Tiny is offline   Reply With Quote
Old 04-26-2016, 12:23 PM   #3
Mitch//pa
Get a hold of Jim brand here on the barn... Jb-ob
Old 04-26-2016, 01:16 PM   #4
Bruce_MO
I had to make up "straw" for my tudor, and I purchased yellow, white and tan from 1-Shot. It took me maybe 10 minutes to get what I liked that matched a chip I had. Make a little bit to get the approximate proportions, then mix a larger amount to provide what you need to stripe the car.
FWIW... the grill insert on a '32 Ford is French Gray. There may be a color you can buy or match
Bruce_MO is offline   Reply With Quote
Old 04-26-2016, 01:45 PM   #5
C26Pinelake
my pin striper had my color premixed when he arrived. I will attempt to contact him to ascertain where the paint was derived from. Wayne
C26Pinelake is offline   Reply With Quote
Old 04-26-2016, 08:05 PM   #6
glenn in camino
glenn in camino's Avatar
You'll have to mix it to match the chip in the paint guide.
glenn in camino is offline   Reply With Quote
Old 04-26-2016, 08:05 PM   #7
30 Tudor and Coupe
John, You can also consider 3M pinstriping tape. It comes in several widths and colors. I don't know if they have one close to what you want but I found one that matched Tacoma Crème that I used on my coupe.
30 Tudor and Coupe is offline   Reply With Quote
Old 04-26-2016, 09:16 PM   #8
billy myers
when I stripe French gray I mix white and black I do my own
billy myers is offline   Reply With Quote
Old 04-26-2016, 11:01 PM   #9
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
John,
Even if you did it in BATTLESHIP GREY, who??? would notice? If they did, who cares. Vermin has straw wheels, I'll put a 1/8" dark blue body COLOR stripe on the wheel rims, to "tie" them to the body color! (IT'S MY CAR!)
Bill Ownman
"THE ASSISTANT GURU OF STUFF"
