04-11-2013, 10:05 PM | #1 |
Generator jumper wire
Hi, I've seen a few post of people talking about keeping a jumper wire in the vehicle in case the cut out goes bad. Where would you jump it from? One side of the cut out to the other?
04-11-2013, 10:07 PM | #2 |
Re: Generator jumper wire
Yes from one side to the other, when you shut the car off ,remove jumper wire.
04-11-2013, 11:10 PM | #3 |
And if the cutout stick closed be sure to remove the wire going to the firewall when you stop the engine, or you can burn up the genertor. I've always used an original cutout and never had a problem with it.
04-11-2013, 11:20 PM | #4 |
Ok, should you connect the jumper wire while it running or before you start it, I tried jumping them with it running and the motor would try shutting off.
04-11-2013, 11:31 PM | #5 |
