Old 02-21-2021, 09:30 PM   #1
dono50
dono50's Avatar
Send a message via MSN to dono50
Arrow Cast iron 2 groove wide belt crank pulley
I have a cast iron 2 groove wide belt crank pulley used on 48-52 ford flathead trucks. These pulleys are pressed steel but never saw a cast iron one. What were they used on ??? If I remember correctly I bought it from a Canadian collector.
dono50 is offline   Reply With Quote
Old 02-22-2021, 01:55 AM   #2
Aarongriffey
Default Re: Cast iron 2 groove wide belt crank pulley
I just pulled a cast iron pulley off the engine in a ‘46 Mercury.
Double pulley, wide belt.
Aarongriffey is offline   Reply With Quote
Old 02-22-2021, 09:43 AM   #3
rotorwrench
rotorwrench's Avatar
The 59 series had a different pulley due to the fan location. Canada always did things a little different than Ford US. They had their own foundry and may have found it less expensive to cast rather then deal with dies and presses for such items.
Old 02-22-2021, 11:01 AM   #4
flatjack9
flatjack9's Avatar
I have never seen a cast pulley wide belt pulley for the 8BA.
Old 02-22-2021, 11:39 AM   #5
dono50
dono50's Avatar
That makes a lot of sense. I installed it on my 8BA engine, no problems. Thanks for your thoughts
Old 02-22-2021, 11:49 AM   #6
Charlie ny
How timely.....the '49 8BA in my '32 had a ci pulley ,2 sheave. When I freshened the motor the iron pulley went on the shelf....it is an anchor.
Charlie ny
Old 02-23-2021, 09:40 AM   #7
dono50
dono50's Avatar
Charlie ny
I have a pressed pulley to replace it, might do so !
Old 02-23-2021, 02:03 PM   #8
1948F-1Pickup
1948F-1Pickup's Avatar
I think C8BA-6312-B is cast into the back side on those.
1948F-1Pickup is offline   Reply With Quote
Old 02-23-2021, 05:30 PM   #9
Ronnieroadster
Ronnieroadster's Avatar
Cast pulleys like yours were common in Australia also.
I use the F word a lot no not that word these words Flathead , Focus and Finish.
"Life Member of the Bonneville 200 MPH Club using a Ford Flathead block"
Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline.
First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH
Old 02-28-2021, 07:17 AM   #10
34 GAZ
34 GAZ's Avatar
German V8 flathead ( Ford Keulen ) has a cast crank pulley for three belts.
34 GAZ is offline   Reply With Quote
