05-02-2020, 08:33 PM | #1 |
Uncle Max Stromberg 97 Tool
Just finished checking a " rebuilt carb" and beside leaking float needle,idle jets jets and PV replacing I also found accelerator jet passage blocked on one side. Treated it with brake cleaner then used the 'Tool" which screws into PV recess. Soon had this sorted and cleared. Carb is now ready for use and leak free. Endorse this great tool for Stromberg carbs. Thanks Uncle Max. Phil NZ |
