Old 07-28-2021, 04:49 AM   #1
Ford1930
Ford1930's Avatar
Default Drum Tail Light
I would like to see an "explosion" drawing of the Drum Tail Light.
When I press the brake pedal the left brake light works. The right one does not work. In stead the right light (below in the drum) works.
What can be the problem?
Ford1930 is offline   Reply With Quote
Old 07-28-2021, 05:14 AM   #2
Patrick L.
Patrick L.'s Avatar
Default Re: Drum Tail Light
What do you mean by light below the drum ?
Do the tail lights work correctly ?
Old 07-28-2021, 06:33 AM   #3
Stew Masche
Stew Masche's Avatar
Sounds like the wires on the right taillight need to be switched around.
Always one bad decision away from a good time.
Stew Masche is offline   Reply With Quote
Old 07-28-2021, 08:07 AM   #4
Patrick L.
Patrick L.'s Avatar
Yep, thats what it sounds like. A simple wiring or ground issue.
Old 07-28-2021, 08:10 AM   #5
Clem Clement
Clem Clement's Avatar
Bring a known good ground to the light case and the socket
Old 07-28-2021, 08:55 AM   #6
Ford1930
Ford1930's Avatar
I made pictures of the drum tail lights when the Brake Pedal is depressed.
The Left Brake Light "burns". The Right Brake light is OFF. Instead the Right Taillight "burns" weakly. What may be the cause?
Old 07-28-2021, 10:29 AM   #7
Bob C
Most likely a bad ground.
Bob C is online now   Reply With Quote
Old 07-28-2021, 10:50 AM   #8
frank55a
Sounds and looks like you have the brake light and tail light wires crossed for the right tail light. To verify turn on the headlights and then check the tail lights if the left lower light burns this is correct. However, if the right top light (brake) burns then the wires to the right light are absolutely hooked up incorrectly. Also note the brake light and tail light bulbs are not the same size i.e., brake light 21 cp tail light 3cp. The lower tail light being 3 cp will burn much dimmer than the brake light 21 cp.
frank55a is offline   Reply With Quote
Old 07-28-2021, 11:31 AM   #9
Patrick L.
Patrick L.'s Avatar
Yep, what Frank said.
The top [ higher candlepower] bulb is brake [and turn light]
The bottom [ lower candle power] bulb is tail light
Wires look crossed, easy fix
Old 07-28-2021, 02:18 PM   #10
Ford1930
Ford1930's Avatar
As advised I made a temporary ground wire. It works. The problem is a bad ground on the right drum tail light!
Thank You ALL for the HELP!
