04-02-2021, 08:44 AM | #1 |
Dr window handle
Window handle won't come off. Stuck a wire in the holes up & down & side way holes clear ( 2 sets of holes ) Clear. What could be holding the handle on ?
04-02-2021, 08:49 AM | #2 |
Re: Dr window handle
There is a set screw as well.
04-02-2021, 12:20 PM | #3 |
A Victoria handle does not have a set screw as a coupe handle does.
If you pushed in the escutcheon to revel the 2 pin locations and there was not a pin in one of them, then someone may have used some other means (glue) to attach it. You will have to gently work it off somehow.
Bill Cilker, Jr Unrestored 190A Victoria 45B, 160B & 189A Victoria Association President |
04-02-2021, 12:39 PM | #4 | |
04-02-2021, 12:43 PM | #5 |
some of the pot metal handles swell up and hold the handle on. and sometimes you end up breaking the shaft trying to remove them. if you know you have the pin removed take a hammer and tap the handle in, to see if you can get it to move. if it does not move. you might have to cut the handle off. I would rather waste a handle than break the shaft. take from one that has broke more than my share of shafts.
04-02-2021, 01:36 PM | #6 |
John may be correct as to the final outcome Good luck |
04-02-2021, 09:17 PM | #7 |
Well the holes are clear, did the taping with the hammer no luck. Will use my Milwaukee m12 3" cut off wheel. I ordered new handles & when they come in I will start.
04-03-2021, 07:10 AM | #8 |
Do you know that the interior door handles in the Victoria are the same as in the Convertible Sedan, except the plating is different. The Victoria handles are plated with nickle, and Convertible Sedan ones are chrome plated.
Bob Bidonde |
04-03-2021, 09:51 AM | #9 |
the 160B&C`s use the same handles as the Victoria and the plating is the same.
the handles in the convertible sedan are bright nickle. |
