01-27-2021, 03:56 PM | #1 |
1928-1931 Model A Cling's Hydraulic Brake Line Kit
City:
Tempe
State:
AZ
Price:
250.00
Purchased this new from Dennis Cling last year and it has been sitting in the box since. I paid $360, selling for $250 shipped. The brake line kit does not include the stop light switch, manifold, master cylinder or lines to the master cylinder as I was planning on using a dual master as opposed to a single which is what the kit would originally include the parts for. If you are using a single reservoir master then you can purchase what is missing from Dennis at www.clingsaftermarket.com
Description from Clings Aftermarket Website: This Specialty Kit takes you from CLING'S Master Cylinder directly to the wheel cylinders with no modification of your car. Complete Kit includes : Mounting Hardware All the necessary fittings Flex Lines - DOT APPROVED Preformed steel lines with double flare NOTE : Rear backing plates must be modified to accept brake lines by rotating them forward. See booklet. How to prepare 1939-48 Hydraulic Backing Plates. Last edited by 28CCPU; 01-27-2021 at 03:59 PM. Reason: adding pics |
03-15-2021, 02:30 PM | #2 |
Re: 1928-1931 Model A Cling's Hydraulic Brake Line Kit
