08-12-2019, 02:14 PM | #1 |
Engine stand adapter question
I found a beautiful engine stand with a model a engine adapter on craigslist awhile back and just now dug it out to work on a re-babbited short block that I recently purchased. This Model A engine adapter is the one sold at Brattons, Macs and possibly other suppliers and is mentioned in threads that I researched on this forum.
However, one thing I can't figure out is why this adapter only has one hole in it for mounting to the stand. So there is not a way to spin the engine upside down while working on it. The standard engine mounting bracket that came with the stand has a bunch of holes in it for mounting an engine at different angles and another larger hole in the end to put a pipe or lever to assist in turning the engine. But the Model A engine stand adapter doesn't have any of that. Just one hole. Is there any reason I shouldn't drill a few more holes in the Model A engine stand adapter to modify it for swiveling?
Jim |
08-12-2019, 02:29 PM | #2 |
Re: Engine stand adapter question
No reason at all. I drill all of mine.
Good Day! |
08-12-2019, 05:28 PM | #3 |
Ok, thanks for the reply Dave. Just wondering why they didn't engineer it that way in the first place as it seems like rotating is probably something a lot of people would want to do working on engines.
Jim |
08-12-2019, 05:41 PM | #4 |
Another way to go is to weld a good sized nut to the stand, and make a "T" handle with the bolt to lock the adapter where you want it..
Early '29 CCPU that had a 4-speed, but not any more.......in the family since '62 |
08-12-2019, 09:13 PM | #5 |
ya could go with the T handle and nut but I would rather have a pin going thru so that 65 pounds of iron at the end of the crankshaft has no way to swing down. Don't forget a hole to lock the engine vertical for doing flywheel housing setup etc
08-13-2019, 06:21 AM | #6 |
Jim |
08-13-2019, 10:56 AM | #7 |
I mounted a gear reduction unit on my engine stand so it can easily be be turned to any angle wanted.
If you don't hear a rumor by 10 AM, start one!. Got my education out behind the barn! Last edited by katy; 08-13-2019 at 10:57 AM. Reason: fixed typo |
