Old 04-16-2015, 05:29 PM   #1
ventura
Default question 40 engine in 35 coupe. What generator do I need?
My generator died. No luck buying local such as NAPA. 40 engine and generator has cutout mounted on top. So, I need to make sure I order right generator.So what year do I order? Thanks. Mike.
ventura is offline   Reply With Quote
Old 04-16-2015, 05:46 PM   #2
Charlie ny
Default Re: question 40 engine in 35 coupe. What generator do I need?
ventura,
It sounds as if you have '35 generator. Cutouts were used up thru , for
the most part '39 standards....'39 delux and some '39 standards ushered in the 2 brush generator with a firewall mounted voltage regulator.
As long as we are "talking" I have 2 show quality fan mounted generators
with diode equipped cutouts..........if you are interested PM me.
Charlie ny
Charlie ny is offline   Reply With Quote
Old 04-16-2015, 06:33 PM   #3
TomTruck
The old 3 brush generator I think is only rated 15 amps and the third brush position sets the current output. The 2 brush unit as used on a 40 Ford is a better unit, is self regulating, and I think is rated up to 30 amps. You must have the correct pulley on it to mount the fan. It uses a voltage regulator mounted on the firewall.
TomTruck is offline   Reply With Quote
Old 04-16-2015, 06:46 PM   #4
russcc
If you are looking for a used original one, or the later one that fits, you may want to call Ray Helgers in RI 401 635 4849. Wed-Sat. 8-3 or something like that. Ray said he was going to Fitchburg on Sunday, so if you are going, you could talk to him in person.
russcc is offline   Reply With Quote
Old 04-16-2015, 06:53 PM   #5
1931 flamingo
1931 flamingo's Avatar
Rebuild yours??
Paul in CT
Old 04-16-2015, 07:19 PM   #6
ventura
I don't think I could do the rebuilding. The wires coming out are all bare and badly couroded.
