Old 03-24-2013, 01:05 PM   #1
Mtn Wudy
Mtn Wudy's Avatar
Default Towing,all four down.
We have a Motorhome and would like to tow our stock 48 behind us 60/70 miles to go beach camping.We tow a 71 VW Bug now with no problems..I read on other posts to overfill the Trans and hold the clutch peddle down when towing.A trailer is not an option as you can only have two vehicles per site..I guess the other option is to teach my wife to drive the Woodie and just tow it past the entrance ..You save $15.00 bucks a day,,,an hey if you there say ten days ,that's $150.00 in my pocket and not in the governor's.....
Thanks Guys. Carl
Whether you think that you can,or that you can't,you are usually right....H.Ford
Mtn Wudy is offline   Reply With Quote
Old 03-24-2013, 01:19 PM   #2
ford38v8
ford38v8's Avatar
Default Re: Towing,all four down.
60-70 miles isn't going to hurt any old Ford. Go for it and use the $150 to buy a round for the house.
Alan
Old 03-24-2013, 01:26 PM   #3
Mart
Mart's Avatar
The woody is a much heavier car than the VW. Also a lot more valuable. It will need a very substantial towing A-Frame. While it is do-able (I have flat towed myself) I'm just wondering if it is worth putting the woody at risk (there is always a risk when towing) to save $150.
Mart.
Old 03-24-2013, 01:29 PM   #4
Ken/Alabama
Ken/Alabama's Avatar
I think the problem is that the bearing in the rear of the input shaft gets starved of oil with the transmission being in neutral . I guess you could tow it with the clutch down but that only works if the transmission is in gear, preferably in hi, but then I would be a little concerned about the pilot bearing in the flywheel running all the time. I have a friend that towed his early Ford and he would stop every now and then and crank it up to let oil circulate in the transmission.
Ken/Alabama is offline   Reply With Quote
Old 03-24-2013, 01:36 PM   #5
Mart
Mart's Avatar
We have discussed recently and there are a few ways to do it. The way I prefer is to leave it in neutral and hold the clutch pedal down. The gearbox internals will tend to rotate purely due to the drag in the box, and keep the lube circulating. It will rotate but not as fast as if in a gear. The clutch release bearing does not rotate as the engine is not turning. I wouldn't start messing about overfilling the trans. In fact, exactly HOW would you set about overfilling the oil level on a side shift trans?
Mart.
Old 03-24-2013, 01:51 PM   #6
51 MERC-CT
51 MERC-CT's Avatar
We used to tow stock cars at least as far (before trailers were the thing)
The only thing we did was put on balding street tires.
When we could'nt tow from the track to back home we had to hire a wrecker and most times it was towed with the rear wheels on the ground due to front end damage.
No holding clutch pedal or overfilling etc.
Old 03-24-2013, 02:06 PM   #7
Rock Hornbuckle
Rock Hornbuckle's Avatar
I don't know how I would survive without a car trailer. It's paid for itself time and time again.
'31 Fordor Deluxe 2W Briggs 170-B / blackwalls
'41 Fordor Deluxe / 2-duece flattie
'66 1/2 Dodge Charger
'14 100th Anniversary Challenger Limited Edition.
Semper Fidelis
Rock Hornbuckle is offline   Reply With Quote
Old 03-24-2013, 02:06 PM   #8
Bill
Bill's Avatar
Teach your wife to drive the woodie--it's just not worth the risk to tow it. Plus she will enjoy all the attention becoming SURFER GIRL Trust me!! Bill
Bill is offline   Reply With Quote
Old 03-24-2013, 03:38 PM   #9
klicker
klicker's Avatar
I just cringe thinking about towing my coupe! Maybe if you can't teach the Mrs. to drive the woodie, she could point the motorhome down the road while you drive....
klicker is offline   Reply With Quote
Old 03-24-2013, 03:51 PM   #10
richard crow
with the car in nutrel the main shaft turns. the first & reverse gear turns. it will throw oil in the trans & lube the rear bearing & main shaft front bearing. the cluster & inport shaft don,t turn
richard crow is offline   Reply With Quote
Old 03-24-2013, 04:46 PM   #11
Cecil/WV
Cecil/WV's Avatar
I wouldn't be afraid to tow it anywhere without damage to the transmission. I towed a '41 pickup from San Diego with a tow bar in 1980 and never hurt a thing. I agree with Richard on this. But, it's your car, so you make the decision.
Cecil/WV is offline   Reply With Quote
Old 03-24-2013, 05:33 PM   #12
rotorwrench
rotorwrench's Avatar
Trailer, dolly, or flat tow is always a risk, no matter how far the way. I had a customer decouple while towing a helicopter on a trailer. He was in too big a hurry to connect his safety chains. He about crapped himself when the helicopter passed him up and went off the road into a house. It didn't damage the helicopter too bad but the house repair cost him plenty. Needless to say, he changed over to a fifth wheel set up after that and took REAL good care of his hook up from then on.
Old 03-24-2013, 05:54 PM   #13
Henry/Kokomo
Henry/Kokomo's Avatar
Re: Mart's question "How would you set about overfilling a side shift transmission?"...........
1. Remove side fill plug (3/8" NPT, I think)
2. Install a 3/8" street ell in the fill hole, pointing up.
3. install a 2" nipple into the street ell.
4. Add gear oil 'til newly constructed standpipe overflows.
5. Install a 3/8 pipe cap.
It would be a super slow process adding the gear oil account, I imagine, venting issues.
Pretty "Rube Goldberg-ish" but I think it could - as opposed to should - be done. FWIW
Henry
Henry/Kokomo is offline   Reply With Quote
Old 03-24-2013, 06:28 PM   #14
1931 flamingo
1931 flamingo's Avatar
Have her drive the motorhome and you the woody................................
Paul in CT
Old 03-24-2013, 11:08 PM   #15
columbiA
Back in 67,I flat towed a model A for 1,200 miles without a problem.The low-reverse gear would dip into the oil & lube the trans.You could always put the car in high gear & pull it a few yards when ever you stop for gas.Always remember to take it out of gear again!
columbiA is offline   Reply With Quote
Old 03-25-2013, 07:14 AM   #16
jimTN
I have pulled one of my 37s from Chicago to TN without a problem and pulled many stock cars with no problems. Over fill the trans and you are liable to have a mess and if oil gets pushed out the front onto the pressure plate......................
jimTN is offline   Reply With Quote
Old 03-25-2013, 09:38 AM   #17
Robert/Texas
Robert/Texas's Avatar
Back in the '50s, I towed my '34 roadster (hotrod) to the drag races, often Houston to San Antonio, about 200 miles. My tow car was my '52 stick-shift Oldsmobile and we towed it as fast as we dared on the roads back then, probably around 65 MPH. It never even occured to me that this would be a problem The '34 had a '40 transmission.
Robert/Texas is offline   Reply With Quote
Old 03-25-2013, 10:09 AM   #18
1931 flamingo
Towed my 32 5W with the 60 impala quite a bit back in the 60's and also never gave it a thought.
Me thinks today we tend to over think everything KISS (Keep It Simple Stupid).
Paul in CT
Old 03-25-2013, 01:05 PM   #19
TomT/Williamsburg
TomT/Williamsburg's Avatar
I would not tow such a beautiful car behind my motor home - on a trailer with a fairing to stop/ward-off road debris, yes. For the few short miles you are talking about, and you are NOT going to put it on a trailer w/fairing (at least if not enclosed), driving it there is probably the safest and simplest thing to do.
TomT/Williamsburg is offline   Reply With Quote
Old 03-25-2013, 06:08 PM   #20
Mtn Wudy
Mtn Wudy's Avatar
Thanks to everyone that chimed in on my thread.......I think I'll teach her the drive the Woodie and follew me...We can stop a mile away from the entrance, hook it up and tow it into the campground...$150.00 "should" keep me more then hydrated the rest of the week.......Skole ,,Carl
