Old 03-15-2013, 04:16 PM   #1
35 coupe
35 coupe's Avatar
Default spindle stud ball 1950 f1
Anybody change a spindle stud ball, are they pressed or threaded in, and when should they be changed. THANKS
35 coupe is offline   Reply With Quote
Old 03-15-2013, 06:00 PM   #2
Ken Crans
Ken Crans's Avatar
Default Re: spindle stud ball 1950 f1
Coupe, It's splined, Must be presssed out. I believe it' s staked on the bottom as well. You could probably tig weld the bad area then grind,file into the original shape. Ken
Ken Crans is offline   Reply With Quote
Old 03-15-2013, 07:34 PM   #3
TomTruck
You can buy replacement balls from Dennis Carpenter and some of the other suppliers. The one I got from Carpenter is similar to the old as they press in and then get peened over. Some of the others require tapping and screwing in.
TomTruck is offline   Reply With Quote
Old 03-15-2013, 09:13 PM   #4
35 coupe
35 coupe's Avatar
Thanks everybody
