04-29-2011, 07:54 PM | #1 |
Engine backfires and does not run smooth
I have my 40 Pickup running now. Has a rebuilt 59-A (by me). It does not run smooth and backfires occasionaly. I suspect I have two cylinder plug wires crossed? It also bucks now and then when I try to drive it? Any suggestions? Thanks, Jack in San Diego
04-29-2011, 08:50 PM | #2 |
Re: Engine backfires and does not run smooth
check your fireing order
If it would have been a snake it would have bit ya! i can't spell my way out of a paper bag! |
04-29-2011, 10:12 PM | #3 |
To checjk the firing order I have to take the distributor off, take the cap off and pull it all apart. I was looking for an easier way. haha (no easy way I guess)
04-29-2011, 10:15 PM | #4 |
Sounds to me like intermittent ignition. Check the back of the key switch. Is it hot? That happened on my '40 and the connection at the switch was loose. A loose connection at the switch will generate a lot of heat at the switch. It should not be hot.
04-29-2011, 11:08 PM | #5 |
what distributor??....what carb??...Mike
04-30-2011, 01:49 AM | #6 |
04-30-2011, 07:07 AM | #7 |
Sounds like dirt in the carb or loose manifold loose/faulty condenser
