Old 08-24-2023, 07:04 PM   #1
Tom Frew
Default Can't get my drums to fit over new brakes 1934 Ford
Installed reclined brakes on my 34 Ford. Now I can't get the drums on. Any suggestions Did anyone else have this problem?
Tom Frew is offline   Reply With Quote
Old 08-24-2023, 07:18 PM   #2
Step-down
Step-down's Avatar
Default Re: Can't get my drums to fit over new brakes 1934 Ford
Did you arch cut your new shoes to fit your drums
"I can't cry as long as I know the Lord has risen "
Step-down is offline   Reply With Quote
Old 08-25-2023, 04:32 AM   #3
ndnchf
ndnchf's Avatar
Assuming you have the adjusters backed off completely, the new shoes need to be ground to match the drum. This was very common practice back in the day. Just about every garage had a brake grinder. Not so today. Check around with local club members, likely someone has one or knows where one is. An old time brake shop may still hve one. I have one myself. It doesn't get much use, but is darn handy when needed.
ndnchf is offline   Reply With Quote
Old 08-25-2023, 12:26 PM   #4
Zeke3
Zeke3's Avatar
Seems like you aren’t the only one. Perhaps this recent discussion will help you with your issue.
https://www.fordbarn.com/forum/showt...%92t+drums+fit
Zeke3 is offline   Reply With Quote
