Old 05-16-2022, 09:51 AM   #1
RalphM
RalphM's Avatar
Default How much rope seal do you leave proud?
I see a lot of different measurements. The little gasket that came with this as a guide is really thin, .015. I don’t trust it, how much should I leave above the pan and timing cover?
I think I should least be an eighth of an inch.The cork gasket measures about .080”. I know the rope will smash down pretty good.
File Type: jpeg C61D858C-110E-414A-B4AF-FCF316CD01C6.jpeg (80.5 KB, 65 views)
RalphM is offline   Reply With Quote
Old 05-16-2022, 12:14 PM   #2
Step-down
Step-down's Avatar
Default Re: How much rope seal do you leave proud?
Best gasket kit Supplys a razor knife and a thin wood shim as a trim guide , seems to work good .
"I can't cry as long as I know the Lord has risen "
Step-down is offline   Reply With Quote
Old 05-16-2022, 12:56 PM   #3
19Fordy
19Fordy's Avatar
How thick is a thin wood shim guide (1/16, 3/32, 1/8, 1/4)?
Ralph: Read everything related to oil pan/crank rope seals you see here. There are lots of thoughts. Some kits give you instructions, some do not.
https://www.google.com/search?q=how+...hrome&ie=UTF-8
Old 05-16-2022, 02:09 PM   #4
flatjack9
flatjack9's Avatar
1/32 to 1/16"
Old 05-16-2022, 02:10 PM   #5
deuce_roadster
deuce_roadster's Avatar
Also, there is better material then that white rope.
Old 05-16-2022, 02:27 PM   #6
Ronnieroadster
Ronnieroadster's Avatar
That's the front rope seal the correct way to install is do not cut anything off the ends. What I do is use a round rod to rub along the seal surface and press down at the same time. You will find the seal pictured will now be a bit lower and actually seal correctly. The ends of the rope seal should touch each other this means the pan gasket should be trimmed so it sits around the outer edges of the rope seal. I have never seen a little thin gasket to be used as a guide for the front rope seal in a gasket set. The rear main seal will have a thin guide used for the purpose of trimming if its the gray black graphite style rear main seal.
Ronnieroadster
I use the F word a lot no not that word these words Flathead , Focus and Finish.
"Life Member of the Bonneville 200 MPH Club using a Ford Flathead block"
Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline.
First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH
Ronnieroadster is offline   Reply With Quote
Old 05-16-2022, 02:39 PM   #7
19Fordy
19Fordy's Avatar
That makes sense. Thanks.
Old 05-16-2022, 03:01 PM   #8
RalphM
RalphM's Avatar
I did push it down/ rolled it with a socket. It doesn’t seem like I’ll be able to get a whole lot more of that excess to go down in there.
So how much will it crush down?
I like the push pins idea, I Will definitely order some of those.
So I read that article, but I did not see the answer to whether the pan gasket goes under the rear cork gasket or just butts up to it. I plan on putting the cork seal in place first, which I think you have to. So it would almost be impossible to put the pan gasket underneath it. So I’m guessing just butt it up and put some RTV on it?
Old 05-16-2022, 03:36 PM   #9
tubman
tubman's Avatar
The last Fel-Pro gasket set I used also had a trim guide, razor knife, and instructions.
Old 05-16-2022, 03:44 PM   #10
ford38v8
ford38v8's Avatar
I jam crammed mine in as best I could, which left big mushrooms at the two ends. I just trimmed the excess mushroom and left the rest, ...Been a while, but I think it was about 3/16" proud at that point. I expected trouble mating pan and timing gear cover, but no problem, and no leaks.
Alan
Old 05-16-2022, 04:26 PM   #11
flatjack9
flatjack9's Avatar
That's for the rear seal.
Old 05-16-2022, 04:30 PM   #12
Ronnieroadster
Trim the pan gasket around the outer edges of the rope seals. Then use a small amount RTV only around the outer area of the rope seal this will seal everything perfectly.
Old 05-16-2022, 05:44 PM   #13
tubman
tubman's Avatar
Ooops! I used it for both ends on the last engine I built and no leaks!
However, when I dropped the pan to replace the flakey Speedway oil pump with a genuine Ford unit, it developed a slight leak in the rear seal. I don't think these were designed for more than one time use.
Old 05-16-2022, 10:01 PM   #14
J Franklin
J Franklin's Avatar
I think the gasket set quality has slipped because I always just used the rope seals as supplied and they weren't meant to be modified. I even remember note inserts saying not to trim them.
J Franklin is online now   Reply With Quote
Old 05-17-2022, 12:21 AM   #15
RalphM
RalphM's Avatar
Well I went back at it and was able to push it in a bit more. About 1/8” to 3/16” above the pan flange. I think it should push together without any trimming, like Ronnie said, when tightening. These pans are not flimsy like some cars nowadays!
Thanks!
Old 05-17-2022, 07:35 AM   #16
Automotive Stud
Automotive Stud's Avatar
Am I the only one who was taught to soak those in oil before installing them?
Automotive Stud is offline   Reply With Quote
Old 05-17-2022, 09:42 AM   #17
alchemy
alchemy's Avatar
No, you aren't.
alchemy is offline   Reply With Quote
Old 05-17-2022, 10:40 AM   #18
RalphM
RalphM's Avatar
I soaked them in New oil for three days.
Old 05-17-2022, 12:35 PM   #19
Bored&Stroked
Bored&Stroked's Avatar
I've never done it any other way . . . or you risk burning the seal up right when you start the engine.
Old 05-17-2022, 02:23 PM   #20
Fritz
Fritz's Avatar
As for the rear main cork seal, I believe the cork pan seal is laid down, then the rear cork seal goes over that. Am I correct with that?
Cars and metal rust away and are destroyed, but the Word of God will stand forever (Isaiah 40:8, Matthew 24:35).
Fritz is offline   Reply With Quote
