05-01-2020, 05:08 PM | #1 |
Choke/Throttle rods
Thanks in advance for all the help you folks have been.
I'm messing with the choke/throttle linkages. Some time back I redid the carb, 91-99. The c/t rods don't function much, It is like I have something wrong in my assembly. One rod is too long and the other too short. What gives, please? Clem |
05-01-2020, 06:16 PM | #2 |
Re: Choke/Throttle rods
Reverse them?
Thanks - 30-9 1939, 1940 |
05-01-2020, 06:26 PM | #3 |
What year?
Rods or cables? Stock intake manifold? |
05-01-2020, 06:40 PM | #4 | |
05-01-2020, 08:59 PM | #5 |
39 Ford standard intake. I did not remove them from the dash holes
05-01-2020, 11:30 PM | #6 |
The carb on my truck is a 91-99 Thanks, Clem |
05-02-2020, 07:18 AM | #7 |
Okay, I'll bite... WHAT YEAR vehicle? WHAT MODEL?
05-02-2020, 08:44 AM | #8 |
39 Ford Pickup
05-02-2020, 09:38 AM | #9 |
Clem, If the rods fit at some point and they were never removed and possibly reinstalled improperly,well, that leaves only "option B".
What has changed since they worked? A properly assembled 91-99 carburetor is correct for your truck. Also, what do you mean by a "39 standard intake"? Truck rods are very different than the passenger car rods.
05-02-2020, 12:15 PM | #10 |
Sorry for not being clear. I'm, still recovering and I so good, don't type
factory intake. 91-99 carb. I'll replace the C/T rods |
05-15-2020, 04:36 PM | #11 |
I gave up. When we can visit I'll get help.
05-15-2020, 07:48 PM | #12 |
Hopefully it won't be too much longer, but us older guys have to be careful!
05-15-2020, 09:34 PM | #13 |
Maybe a photo or 2 would help shed some light on it?
Making the simple complicated for over 30 years. |
08-22-2020, 10:05 PM | #14 |
Worked in the rods again today. Bought a pair of rods from a Barner. The choke rod has a loop-de-loop to shorten it The Throttle is long as well. I have kept the originals in and made some improvements. the carb us a 91-99 the carb is raised 3/4" by the phenolic block. Wrong carb?
08-22-2020, 10:26 PM | #15 |
The phenolic spacer is probably the issue. When I added one on my '38 the rods protrude 3/8" - 1/2" into the cab past their previous position on the dash. I just put the same thickness rubber washer in behind the knobs so it looks clean and if I remove the phenolic spacer the rods will fit as they did before.
08-23-2020, 10:17 AM | #16 |
Thanks. Great idea. I can split vacuum hoses to cover the rods and be a stop for the push - in action.
Did the phenolic block help with vapor lock? |
08-23-2020, 11:00 AM | #17 |
I'm going to say yes but I think I had other issues as well which have since been resolved. Either way I left it on and have not vapor locked since the install.
08-27-2020, 02:07 AM | #18 |
Thanks Barners. I am still recovering from heart procedures and am very slow. I took time off from car work during the hot summer. I am slowly starting again. Thanks for understanding.
I split 2 short pieces of vacuum hose and put them over the choke/throttle rods. Looks good in the cockpit. |
08-27-2020, 03:31 PM | #19 |
Heart surgery is always fun, I've had a quad-bypass.
08-27-2020, 03:39 PM | #20 |
