10-06-2019, 05:05 PM | #1 |
Transmission dipstick kit
Is anyone using a dipstick kit to check level of oil in the trans?
10-06-2019, 05:15 PM | #2 |
Re: Transmission dipstick kit
Nope, not me.
10-06-2019, 06:41 PM | #3 |
The Coupe that I just bought had one in already.
Mike |
10-06-2019, 06:45 PM | #4 |
YES!! Love it too
10-06-2019, 08:47 PM | #5 |
I put one on my coupe. Purchased from Mitchel OD/trans mfg. I’m 82 and limit my time under the A if possible. Cut a hole in the floor board and pull the carpet back to access the dip stick. YEA, no more back pain! 👍 😊
10-06-2019, 10:40 PM | #6 |
But it is still easier than crawling/squeezing under the car in the dirt, and lying on your back with oil dripping down you wrists and into your face. W. Michael |
10-07-2019, 07:09 AM | #7 |
I am and really like it. Easy to install.
If it aint broke, don't fix it! |
10-07-2019, 10:10 AM | #8 |
I have one, use for same reasons as post 5, back issues.
I also installed the Battery access kit so I do not have to remove the entire lower floor board to remove/install/service the battery. Type in Macs parts, search for battery kit. Tried to include a link, but keeps going to a Ecklers Corvette parts page. Last edited by 30 Closed Cab PU; 10-07-2019 at 10:26 AM. Reason: link did not work |
10-07-2019, 10:14 AM | #9 |
Only downside, would be nice if they made a trans kit where the tube/dip stick stuck above the floor. Then there would be no need to pull the floor covering and access plate up.
10-08-2019, 10:34 AM | #10 |
My solution to ease access to the transmission fill plug.
Bob Bidonde |
10-08-2019, 01:49 PM | #11 |
Hey Bob,
I like your gearshift nob. It looks like it's an antique door knob. I grew up in the '40's and '50's in a house that was built in the late 1890's or early 1900's. All our doors had that type of door nobs. David Serrano |
10-08-2019, 02:20 PM | #12 |
Hi Fred, yes I have it since 9 month. It is a good idea. I would buy it again.
Beste Gruesse aus Deutschland, Werner Ford Model A, Roadster, 1928 Citroen 11 CV, 1947 Hercules W 2000, 1976; (with NSU-Wankel Rotary Engine), Canadian version |
