Old 01-31-2018, 07:03 PM   #1
Nelson C
Default 1931 S/W Fordor Sedan Questions
Please help with the following relative to a 1931 S/W Fordor:
1) Does the front seat use a Seat Adjuster Spring (6" long x 1" OD)?
2) How does the windshield wiper get mounted?
Thank you.
Nelson C is offline   Reply With Quote
Old 01-31-2018, 09:02 PM   #2
jw hash
jw hash's Avatar
Default Re: 1931 S/W Fordor Sedan Questions
the spring sound about right, the wiper motor is mounted through the header and on the outside a small rubber washer, plated washer, and a special chrome plated nut. when you tighten the nut it pull the motor into the upper interior panel to keep it from moving. it sounds kind of half ass but that is the way it is.
jw hash is offline   Reply With Quote
Old 01-31-2018, 09:19 PM   #3
Jim/GA
Jim/GA's Avatar
Thank you.
1) Sounds about right. It helps you slide the seat forward when you have raised the handle on the saw-tooth style adjuster.
2) See Area 20 of the Restoration Guidelines for details
"Vacuum Wiper Mounting
Slant Windshield Sedans used an inside mounted wiper held by the shaft collar. A nut (finished to match the wiper) secured the wiper in place."
Jim Cannon
Former MAFCA Technical Director
"Have a Model A day!"
Jim/GA is offline   Reply With Quote
Old 01-31-2018, 11:03 PM   #4
Mike85212
Mike85212's Avatar
I have a Slant Window...my seat adjuster is a knurled knob...no spring.
My windshield wiper is mounted on the inside and is vacuum operated. The wiper motor still works and although I daily drive my car since purchasing it in October it has only sprinkled one time... I have the impression that even with a brand new wiper arm and blade the wiper is nearly useless.
Mike
Mike85212 is offline   Reply With Quote
Old 02-01-2018, 10:46 AM   #5
Nelson C
Thanks for the responses. This car's front seat has a Saw Tooth Seat Adj Ratchet Assembly with a slightly curved Seat Adj Handle.
Where does the 6" long Seat Adj Spring attach to, so it pulls the seat forward?
Would it use the metal 2"x 2" Seat Clip with two holes for screws somewhere?
Old 02-01-2018, 11:10 AM   #6
burner31
burner31's Avatar
Hope these help
Keith
Shawnee OK
'31 SW 160-B
burner31 is offline   Reply With Quote
Old 02-01-2018, 11:31 AM   #7
duke36
here's a wiper exterior photo though with the deluxe arm
duke36 is offline   Reply With Quote
Old 02-01-2018, 01:18 PM   #8
Nelson C
Thank you all for responding.
The photos were particularly helpful.
Have a great day!
