Old 05-12-2022, 05:41 PM   #1
Step-down
Step-down's Avatar
Default subaru thermostat
Can any one recall which year Subaru thermostat we use in our V8 flathead
I have in my 59 but can’t recall year and which model .
"I can't cry as long as I know the Lord has risen "
Step-down is offline   Reply With Quote
Old 05-12-2022, 05:58 PM   #2
drolston
drolston's Avatar
Default Re: subaru thermostat
I don't remember the year and model, but it is a Stant 14157. 170 degrees. Works fine in my big inch flathead, but you will need something to keep it in place. They can flip or go up the hose. I put two 3/16 holes in mine to let a little flow through, because otherwise they are up away from the engine heat and will delay opening. Mine would show full hot on the temp gauge and then drop back down to just above the mid mark. No real harm done, but I would rather avoid those anxious moments waiting for the temp to drop down. The effect on engine warm up time is not noticeable.
File Type: jpg Thermostat with holes added smaller.jpg (49.2 KB, 77 views)
Old 05-12-2022, 06:51 PM   #3
Step-down
Step-down's Avatar
Thanks drolston , that’s the one
Old 05-12-2022, 07:19 PM   #4
flatjack9
flatjack9's Avatar
I would use 180 deg thermostats. Part no.45848
Old 05-12-2022, 07:35 PM   #5
1931 flamingo
1931 flamingo's Avatar
Suburu Justy stats.
Paul in CT
Old 05-13-2022, 05:37 PM   #6
Step-down
Step-down's Avatar
Thanks guys
Old 05-15-2022, 04:42 PM   #7
Shoebox
Shoebox's Avatar
I ordered a pair of 45848 thermostats and I love the quality but they're too small, OD is about 1 11/16". Wrong part in box or am I missing something?
I went, I saw, I bought the T shirt
51 Ford Deluxe Tudor
32 Ford roadster
39 Mercury Towncar
Shoebox is offline   Reply With Quote
Old 05-15-2022, 08:30 PM   #8
flatjack9
flatjack9's Avatar
The original post was for a thermostat for a 59A engine. The 8BA uses a different thermostat. I don't have the number at home. I'll have to check at the shop tomorrow.
