Old 11-03-2020, 08:16 PM   #1
TMarsh
Red face manifold leak
Just thought I would pass this on, had an exhaust leak in the area of the number four exhaust port. Removed the intake and exhaust and found them to be true and level. Noticed valve cover gasket protruding about a quarter of an inch above the valve cover. Apparently this caused the manifold and gasket not to seat properly against the head. The new gasket practically touches the valve cover itself, therefore the protruding valve cover gasket held the manifold slightly away from the head. At 1800 miles the cork apparently burned away and a leak developed. Cut the exposed cork gasket on the valve cover and installed new manifold gasket and all is well.
Sometimes the fix is so simple it escapes us.
TMarsh is offline   Reply With Quote
Old 11-03-2020, 10:22 PM   #2
Gary WA
Gary WA's Avatar
Default Re: manifold leak
Thanks for info,!!
www.whidbeymodelaclub.com
Old 11-04-2020, 08:10 PM   #3
wwirz
Did you use the copper shrouded gaskets and split rings? Paul Shinn on YOUTUBE has a great video on replacing the intake/exhaust manifold gaskets.
wwirz is offline   Reply With Quote
Old 11-04-2020, 08:57 PM   #4
TMarsh
My 30 coupe is not set up for gland rings. I used a one piece gasket with the metal on the side facing the manifold and the paper side toward the head, no gasket sealer used.
Old 11-04-2020, 10:38 PM   #5
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
Haven’t used gland rings for years
Thread Tools
Display Modes
