Old 12-23-2019, 11:22 PM   #1
Dewey29
Dewey29's Avatar
Default 29' 2 Tooth Steering Question
I've been a member of this forum for a while now but I've never posted. I've learned a lot from you guys, so I'd first like to say THANKS!
This may be more complicated than I'm thinking but I'd like to change my 7 tooth steering to a 2 tooth in my 29 roadster. I have a really nice 30/31 2 tooth box (A-3550-C), I also have a 29 style (37") column tube and an extra 29 keyed steering wheel.
My question is if I put a new 34" Gemmer steering shaft w/worm gear in the 30/31 box and use the 29 column tube will it essentially work as a 29 2 tooth steering unit? If so, will it also work with the original 7 tooth spark/gas rods and a 29 style 45" horn rod (A-3616-C)?
Thanks!
Dewey29 is offline   Reply With Quote
Old 12-24-2019, 06:42 AM   #2
ryanheacox
ryanheacox's Avatar
Default Re: 29' 2 Tooth Steering Question
I believe you are correct although I think the shaft length you need is 43”. Welcome to the forum!
Old 12-24-2019, 07:49 AM   #3
Dewey29
Dewey29's Avatar
You are correct, my bad on the typo. Thanks
Old 12-24-2019, 09:42 AM   #4
rotorwrench
rotorwrench's Avatar
This has been a common mod for many years to get the 2-tooth in the earlier cars with 7.
Old 12-24-2019, 01:09 PM   #5
fuzes45
Put in steering column support 31 style that does not mount on gas tank.
fuzes45 is offline   Reply With Quote
