Old 04-06-2013, 06:08 PM   #1
cooke
cooke's Avatar
Default ammeter problems
I have what I think is a repop ammeter that is not working properly. It is at 3 amps plus when the car is off and goes to 18 when I am running the car then when I shut the car off it is at 10 til I tap it and goes back to about 3plus. Are these difficult to repair?
cooke is offline   Reply With Quote
Old 04-06-2013, 06:14 PM   #2
700rpm
700rpm's Avatar
Default Re: ammeter problems
Easier to replace. Use an original if you can find one (I've been looking for over a year without success).
Ray Horton, Portland, OR
Old 04-06-2013, 07:42 PM   #3
Tom Wesenberg
Tom Wesenberg's Avatar
A drop of oil on each of the 2 pivot points helps, and you can bend the needle over to center quite easily, but as Ray mentioned, an original is better quality and fit. Original ammeters have black paint on the brass internals, which the repro's I've seen don't. Also repro's use hex nuts on the back and originals use special slotted nuts, like those on the slant pole coils.
Old 04-07-2013, 06:24 PM   #4
1931 flamingo
1931 flamingo's Avatar
DISCONNECT the battery before you pull the inst panel to investigate. FWIW
Paul in CT
1931 flamingo is online now   Reply With Quote
Old 04-07-2013, 06:41 PM   #5
jkcrosson
jkcrosson's Avatar
I was fortunate to find one on ebay a couple weeks ago that Dick Crabtree had listed. It works great. Originals do pop up. I search "model a ford ammeter" on a regular basis.
Jamie Crosson
1929 Tudor
Looking for an Original 888 Key
jkcrosson is offline   Reply With Quote
Old 04-08-2013, 09:54 AM   #6
Big John
get an original... will work much better they're out there........
Big John is offline   Reply With Quote
Old 01-20-2021, 01:55 PM   #7
rickranger
If you weren't worried so much about an original look, why not use a quality off the shelf ammeter that will fit the same opening?
rickranger is offline   Reply With Quote
Old 01-20-2021, 02:49 PM   #8
Y-Blockhead
Y-Blockhead's Avatar
Can't say I have ever seen "a quality off the shelf ammeter that will fit the same opening"... If you know of one, please let us know.
Old 01-20-2021, 05:28 PM   #9
rickranger
Ha. Will do.
Old 01-20-2021, 07:15 PM   #10
Dale G.
Dale G.'s Avatar
I have restored original ammeters for sale. $55 to $65 each. 904-731-0367. Call mornings, 9am to noon. Thank you. Dale Gosa.
Dale G. is offline   Reply With Quote
Old 01-22-2021, 03:49 AM   #11
ronn
I bought a couple at Carlisle this fall and they were repos from possibly the 1960s?
very good quality.
Old 03-25-2021, 10:26 PM   #12
GT1929
Hello, I have one that glass broke trying to fit the ammeter into repo dash. The ammeter came to bits and I can't work out how to get the needle refitted? Does it go between the brass and allie bit with the needle on it?
Cheers Graeme
GT1929 is offline   Reply With Quote
