Old 12-03-2023, 11:53 PM   #1
OldGold360
Default Timer Question
Which brand timer does you all prefer? Thanks!
OldGold360 is offline   Reply With Quote
Old 12-04-2023, 09:44 AM   #2
redmodelt
redmodelt's Avatar
Default Re: Timer Question
Original New Day or current reproduction of same. The original had Pat. under where the timing rod fits. Stay away from the ones with the "S" in the same spot, the material used is too soft. Next in line would be the original style roller type. Never have been a fan of the Anderson.
Old 12-04-2023, 11:15 AM   #3
Will N
Will N's Avatar
The New Day is more forgiving if your timing cover is not aligned. The roller timer will wallow out the timer case if the cover is not aligned (it happened to me). The I have had nothing but good luck with the Anderson (flapper) timer I have installed now.
Will N is offline   Reply With Quote
Old 12-05-2023, 11:14 AM   #4
OldGold360
Thanks! I ordered a New Day. Sounds like they work well.
Old 12-05-2023, 02:02 PM   #5
mechanicalarts
mechanicalarts's Avatar
I run either Anco Flapper style timer or crystal timer. Both work great and have toured many miles with both. In my customer cars I install Ancos.
mechanicalarts is offline   Reply With Quote
