11-14-2017, 01:32 PM | #1 |
Need Source for engine part common to 35-48
I need an Adapter (fuel pump mounting) pn 48 9415. It is mounted on the rear of the intake manifold. The fuel pump is attached to it and the oil filler/breather cap is on top. It's illustration is on page 214 of the "green book" and the pn is shown on page 420. Can you point me in the right direction? Thanks a lot. Bill
11-14-2017, 01:57 PM | #2 |
Re: Need Source for engine part common to 35-48
Bill, These are all over places like eBay. I think Drake makes them as well.
11-14-2017, 02:35 PM | #3 |
Be aware that the fuel pump push rod must match the stand. The main difference is whether the intake manifold is cast iron or aluminum. Aluminum type is 7.87", and the iron is 8.87", and are not interchangeable.
11-14-2017, 03:16 PM | #4 |
Is the only difference the length of the rod?
Thank you. |
11-14-2017, 04:05 PM | #5 |
Just to clarify - the stands are the same height. The intake manifold makes the difference in which rod is required. As stated in the previous post, the factory aluminum intake requires the (1") shorter rod than the cast iron intake.
11-14-2017, 05:23 PM | #6 |
11-14-2017, 06:31 PM | #7 |
We have good used originals in stock if you don’t find one out there
VANPELT SALES LLC Cincinnati, Ohio Office: 513-724-9486 www.vanpeltsales.com www.classictransmission.com |
