08-24-2016, 09:01 PM | #1 |
33,34,and 35 Spare Tire Cover Dimensions and related Tire Sizes
Does anyone have dimensions for 1933, 1934 and 1935 Ford Spare Tire covers and the corresponding tire sizes these fit? I have a 1934 Ford Fordor with a spare tire mount but without a spare tire and want to purchase a spare tire cover, and then a wheel and tire to fit. I figure I will start with the cover, as that is harder to find. Once I have that, the wheel and tire should be simple. I see some original covers on line but the dimensions reported seem to be all over the map, and I'm not sure they really have the correct year identified - or that it is really for a Ford. The spare doesn't necessarily need to be for a 34, as my car has 15" aftermarket wire wheels, so likely anything I get won't be a functional spare - just for looks.
What I would like to know is the OD and ID of the face cover, and the width and OD of the tread cover for 33, 34 and 35 - and what tire size corresponds to these. I know that 33 & 34 wheels are 17" and 35 wheels are 16". |
08-24-2016, 09:19 PM | #2 |
Re: 33,34,and 35 Spare Tire Cover Dimensions and related Tire Sizes
The 33,34,and35 face plates have stainless trim rings. The first one I found for my car was 27 3/4 X15 7/8 and it just didn't seem large enough in diameter to work. Then I found one 28 3/16 X 15 and it fit perfect. I will admit I've found a lot of different sizes while searching.
08-24-2016, 10:34 PM | #3 |
Hi Jim, 1933 & 1934 face plates measure 28 1/4" outside diameter. Centre opening is 15 3/4" across. 1935 face plate is 27 1/4" outside diameter with a centre opening of 14 3/4" across. I think the tire tread covers are all the same except for the pressing raised up section hump (34 is wider than 33) and the 33 has a stainless ring moulding around it mounted in the centre of the hump. The stainless moulding or trim on the faceplates are different widths between 33/34 and 35. 1933-34 is 9/16" wide. 1935 is more narrow at 3/8" wide. Trim rings on 1935 are held to the face plate with spring clips and 34 has threaded fasteners with nuts on the back of the face plate. I have noticed very slight variations in these measurements on various covers and trims but the above is a pretty good guide. Regards, Kevin.
08-24-2016, 11:25 PM | #4 |
The outer bands for all three years are different. The circumferential bead on the '33 beneath the stainless steel moulding is smaller in width than that of a '34 without a moulding. The wider (6.00 x 16) tire size of the '35 required a wider band than the '33-'34s which had 5.25 X 17 tires (5 3/4" width versus 5 1/2" for '33-'34 tire bands).
08-25-2016, 08:03 AM | #5 |
Jim G., Here is a summary of 35/36 Spare Tire Covers. This summary includes covers for 6.00 x 16, 6.50 x 16 and 5.50 x 16 tires. This should help a little in weeding thru the covers.
Don Rogers |
08-29-2016, 06:13 PM | #6 |
08-31-2016, 07:39 AM | #7 |
I am very impressed by how friendly, helpful and prompt everyone on this site is in answering questions that are posted. I'm very impressed. Thanks again!
