Old 05-16-2015, 10:51 PM   #1
fordor41
fordor41's Avatar
Default neutral safety switch
A friend of mine just finished restoring his parents '57 Ford fairlane convert, 312 automatic. I watched him start it and he put it in neutral. I asked him why and he said that was a "safety" feature by Ford that it could only be started in neutral. I've had 2 '57 Fords with automatics and they all started in park or neutral. He showed me the original owners manual and it said "to start the car with conventional or overdrive tranmissions to place it in neutral". I told him conventional/overdrive referred to 3 speed standard not autos. I'm trying to convince him that the neutral safety switch has gone south in the park position.
Anyone agree with me?
fordor41 is online now   Reply With Quote
Old 05-16-2015, 11:00 PM   #2
Paul H
Default Re: neutral safety switch
57 Fords were all neutral start only.If yours started in park,someone had replaced the switch with one from a 58 or newer car(or truck)
Paul H.
Paul H is offline   Reply With Quote
Old 05-17-2015, 02:58 AM   #3
ThomasN
ThomasN's Avatar
Or, just jumper around it. My stock 53 only starts in neutral ad that is what the manual says
ThomasN is offline   Reply With Quote
Old 05-17-2015, 07:16 AM   #4
darrell
56 was last year for neutral start only.
darrell is offline   Reply With Quote
Old 05-17-2015, 01:42 PM   #5
darrell
you lost me on that one.if your friends 57 starts in neutral only he has a 56 switch.56 and 57 switches are interchangeable which is why most people put a 57 switch on their 56 when they need one.all 57s start in park.like fordor i owned 2 57s and drove around in dozens of them.
Old 05-17-2015, 07:48 PM   #6
paul2748
paul2748's Avatar
I know the 57 Birds started in neutral only. In 58 they changed to start in both neutral and park. I assume the sedans were the same
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 05-17-2015, 11:05 PM   #7
fordor41
fordor41's Avatar
It's hard to believe that some one changed both NSS's on my '57s to a later style and like Darrel,l I got lost on these post. Seems like we're 50/50 on park start or no park start. remember we're talking auto transmission.
Old 05-18-2015, 07:09 AM   #8
oldave57
I have owned two 57 Fords, one when I was 18 years old (a looong time ago) and one now. Both of these had Fordomatics and both only started with the gear selector in Neutral. I have modified my current car by adding a contact switch so that the linkage lever would contact the switch when the selector is in Park, and now the car starts in either Park or Neutral (like it better that way). I do know that the 58 Ford neutral safety switch was changed to start in either Park or Neutral, but the 57 switch started only in Neutral.
I have attached a picture of the 57 Ford Operator's Manual that shows the section on starting and it states that the safety feature prevents starting unless the selector is in Neutral.
Regards,
Dave
oldave57 is offline   Reply With Quote
Old 03-29-2016, 07:35 PM   #9
Crestliner2
would these 58 switches fit a 52? I currently have a NSS that the arm broke off. I would either like to bypass the switch safely or replace it. but I am having a hard time finding a switch for that year.
Crestliner2 is offline   Reply With Quote
Old 04-09-2021, 10:06 AM   #10
terminator2372
What did you end up doing on your NSS? I'm pretty sure my 52 Customline is also having a NSS issue and I want to bypass it too.
Thanks,
Jason
terminator2372 is offline   Reply With Quote
Old 04-09-2021, 10:40 AM   #11
dmsfrr
dmsfrr's Avatar
Originally Posted by terminator2372 View Post
... I'm pretty sure my 52 Customline is also having a NSS issue and I want to bypass it too.
Thanks,
Jason
If you bypass the NSS the car can be started in any gear. Very dangerous if the car is on a roll-on platform at a service shop somewhere. (even in your own garage if you aren't paying attention)
They were originally made to start the car only in Neutral to avoid having to shift past Reverse every time you were headed for Drive, to cut down on wear & tear to the reverse gear parts. Still a valid concern with an older transmission.
terminator2372, resurrecting old threads is generally not done because it quickly gets confusing knowing who to respond to and about what... a question resolved years ago or the most recent comment.
Old 04-18-2016, 11:30 PM   #12
zuburg
zuburg's Avatar
I just bought a Neutral Safety Switch from one of the Tbird Parts houses (Concours I think), that will allow starting in Park. It has four wires, two with male ends, and two with female connectors. Can anyone tell me what I will find when I remove the old original neutral safety switch? Will it also have four wires?
zuburg is offline   Reply With Quote
Old 05-31-2015, 10:07 AM   #13
Ford blue blood
Ford blue blood's Avatar
olddave57 is correct. 57 Fords only started in N when equiped with an automatic. There was no switch for manuals. 58 was the first year for P and N starting. All three of my 57s have/had N only. Original and replacement switches for automatic cars had two sets of terminals, one set for the safety and one set for the backup lights. My Ranchero has no backup lights but does have the original switch with both sets of terminals.
Bill, certified Ford nut.
2016 F-150
2016 Focus
08 Shelby GT500
57 Ford Ranchero
36 Chevy, 351C/FMX, 8", Mustang II
Ford blue blood is offline   Reply With Quote
Old 05-31-2015, 11:39 AM   #14
scicala
scicala's Avatar
To make things more confusing, I know it's not a Ford, but my '55 Mercury Montclair that I had back in '65, started in park and neutral (Mercomatic).
Sal
scicala is offline   Reply With Quote
Old 05-31-2015, 11:54 AM   #15
GAR64
When I first got my 56 Victoria I was convinced the NSS was defective until I read the manual...
GAR64 is offline   Reply With Quote
Old 05-31-2015, 11:46 PM   #16
SSsssteamer
SSsssteamer's Avatar
Both my 1957 Skyliner and my 1957 Thunderbird with automatics only start in neutral. And that is the way they were meant to be by Ford. If you want your 1957 Ford to also start in Park, then install and 1958 Ford neutral switch into your 1957 Ford. It is a common installation. 1958 neutral switches are available on eBay.
SSsssteamer is offline   Reply With Quote
Old 03-29-2016, 11:03 PM   #17
Kahuna
Kahuna's Avatar
Crestliner2
I have no idea what a 52 switch actuator looks like. But if it is the same or similar to 54-56, then you can use this:
C1TF-7A247-A. This is a Ford number
1960-1966 Ford truck with Auto. Starts in Neutral & Park
Kahuna is offline   Reply With Quote
Old 04-19-2016, 12:51 AM   #18
dmsfrr
dmsfrr's Avatar
The car should have 4 wires, esp. if it has the back-up light option. The new switch should have 4 wires also. The wire colors & connectors on the new switch will most likely match the old ones.
Two wires are for the NSS and the other two are for the back-up lights.
No clue what else you'll find, the only similar example car I've got that switch & it's wiring was missing and I suspect the PO bypassed it under the dash somewhere. It's on my to-do list.
Old 04-19-2016, 08:48 AM   #19
zuburg
zuburg's Avatar
Thanks, I'll let you know what I find, and how easy it was or wasn't to replace. I won't know if it works or not for awhile as I'm waiting for my Fordomatic to be rebuilt and new engine is not yet ready to be installed.
Old 04-19-2016, 07:34 PM   #20
paul2748
paul2748's Avatar
Since the switch attaches to the shifter, it should be easy to install with no trans in the car.
48 Ford Conv
56 Tbird
54 Ford Victoria
