09-06-2021, 10:05 PM | #1 |
12 Volt Bosch Blue Coil
What should the readings for a Bosch Blue Coil be for primary and secondary resistance? How does this compare to a standard 12 volt coil?
09-07-2021, 10:31 AM | #2 |
Re: 12 Volt Bosch Blue Coil
https://www.ratwell.com/technical/BlueCoil.html Then follow this procedure. http://forums.pelicanparts.com/porsc...osch-coil.html |
