Old 05-19-2012, 08:05 AM   #1
Modelakid31
Send a message via AIM to Modelakid31
Default which method is best for setting the valve clearence?
I have a 15 T and just did all the valves over and now im stuck on setti g the clearence. What method do you guys think is the best way to set them?
Thanks.
Modelakid31 is offline   Reply With Quote
Old 05-19-2012, 08:15 AM   #2
Modelakid31
Default Re: which method is best for setting the valve clearence?
I have a stock original engine with aluminum pistons. I set everything using the piston travel method using the krw type T guage. Im getting about .026 on intake 1.
I was wondering if i should use the Chaffin method setting all the valves at .015?
With the chaffin method how acurate do you need to be with the top openning of each valve? Is it necessary to use a dial indictor or is it not real critical? Same question on finding the exact 360 crank point as there is little reference on the block with the markings you put on the crank pulley
Old 05-19-2012, 08:46 PM   #3
Doug Money
Doug Money's Avatar
"What method do you guys think is the best way to set them?" Depends on what cam you have.
"Same question on finding the exact 360 crank point as there is little reference on the block with the markings you put on the crank pulley "
Use a gauge on the piston itself to reference the piston position.
Doug Money is offline   Reply With Quote
Old 05-20-2012, 01:32 AM   #4
dumb person
dumb person's Avatar
i set them at 0.15 because i have no idea how butchered the block was. If the top of the blocked was planed in the past that changes the cam' setting if you use piston position. i would say set them at 0.15 but you might be more traditionalist than i am.
.... Now that i think about it maybe 0.15 was way too much and should have used 0.015
dumb person is offline   Reply With Quote
Old 05-20-2012, 07:52 AM   #5
Doug Money
Doug Money's Avatar
Height of the block doesn't matter, you are setting from piston movement. If you are using a known good aftermarket cam use clearance method. If you are using original worn cam, use valve timing method.
