Old 11-26-2021, 03:24 PM   #1
hangarb7
Default overheated motor won't start now
I got a text from a club member, "I checked the oil and gas but failed to check the water. About a mile from the garage smoke comes from everywhere and the engine stops. Engine badly overheated. Got water into the radiator but the engine won't fire. It turns over okay. I called AAA and they flatbedded it back to the garage. Any recommendations? "
I know an engine needs fuel and spark but before I go over there to check it out, what should I look for? Head gasket?
Thanks
hangarb7 is offline   Reply With Quote
Old 11-26-2021, 03:38 PM   #2
Crankster
Crankster's Avatar
Compression check maybe? A consequence of severe engine overheating is piston rings lose their spring tension.
Crankster is offline   Reply With Quote
Old 11-26-2021, 04:23 PM   #3
daren007
Default Re: overheated motor won't start now
Squirt oil into the cylinders then turn the engine over several times with the starter. Reinstall spark plugs, start up and drive away.
daren007 is offline   Reply With Quote
Old 11-26-2021, 04:28 PM   #4
Synchro909
Synchro909's Avatar
Was the engine still hot when you put water in it?
Old 11-26-2021, 05:41 PM   #5
nkaminar
nkaminar's Avatar
Spark, fuel, and compression. Easy to check for a spark at the plugs by having the leads about 1/4 inch away from the top of the plugs or 1/4 inch away from the terminals on the distributor top. You can squirt some gasoline in the carburetor to see if it starts. If it starts and then quits you need to trouble shoot the fuel system and perhaps the carburetor. Checking the compression is easy by turning the engine over with the hand crank. You should feel some resistance on all 4 cylinders.
Do the above before you start pulling things apart and then report back to the Barn animals.
Old 11-26-2021, 05:46 PM   #6
McMimmcs
McMimmcs's Avatar
I agree totally. Too many people start tearing apart before they try the simple causes first.
Old 11-26-2021, 06:55 PM   #7
old ugly
old ugly's Avatar
pull the plugs and see if they are wet with gas or maybe wet with water(hopefully not)
easy first check.
old ugly
my old father-in-law told me. "listen close when people tell you how to do stuff they may know something. then do it the way you want."
old ugly is offline   Reply With Quote
Old 11-27-2021, 12:49 PM   #8
burner31
burner31's Avatar
Once you get it going again you may want to consider a motometer and / or a temp gauge
Keith
Shawnee OK
'31 SW 160-B
Old 11-27-2021, 05:30 PM   #9
Marshall V. Daut
Check your "Private Messages" in the top right corner of this webpage.
Marshall
Marshall V. Daut is offline   Reply With Quote
Old 11-27-2021, 07:06 PM   #10
PC/SR
Severely Over heated mine, would start but would not run more than aboiut 30 secs, lots of searching, ultimately it was the condenser. Quick and easy. Try that first. Let us know when you get it going.,
PC/SR is offline   Reply With Quote
Old 11-27-2021, 09:32 PM   #11
Crankster
Crankster's Avatar
Default Won't start now
Yabut, he says first thiing it has spark and fuel..
I'd try squirting some earl in all the cylinders as mentioned and hope nothing got toasted too badly.
Old 11-27-2021, 11:37 PM   #12
Synchro909
Synchro909's Avatar
Default Re: Won't start now
What is earl???
Old 11-27-2021, 11:49 PM   #13
PC/SR
He said he knows it needs spark and fuel but it is a friends car. I did not see him say it has spark and fuel. Earl is American slang for oil.
Old 11-28-2021, 06:59 AM   #14
Jacksonlll
Jacksonlll's Avatar
The rubbing block on the points is probably melted. Easy to check.
Old 11-30-2021, 05:39 AM   #15
ronn
why I use pure synthetic. Engines never freeze with it.
Old 11-30-2021, 05:59 AM   #16
ETAModel
I drained 3/4 gallon of water from the 30 Fordor and cranked her up to add antifreeze. I got distracted and looked up to see steam coming from the open radiator cap. I hurriedly put a gallon of Prestone in it and it stopped steaming, then topped her off with 50/50 antifreeze. I was surprised how quick it got hot. I guess that's why they call them "Hot Water Fords."
ETAModel is offline   Reply With Quote
Old 11-30-2021, 09:01 AM   #17
Big hammer
Something else anti-freeze will kill, spark plugs, the spark plugs will not work after getting anti-freeze on them I’ve been told.
get a bigger hammer tap done
Old 11-30-2021, 09:45 AM   #18
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Oooo guys, I'm not sure this is sound advice.
Before we get too far into this, consider several things. When I have one that comes in that has been overheated, I am not interested in doing compression checks. These pictures below are from a vehicle that was similar in that it was run without water. The visual signs on the outside showed it was hot down into the cylinder walls. On this particular vehicle, it had oil on the rings which would have given a false reading on a compression check. The bigger issues with this engine is it had a warped deck that still had the head gasket sealing however as soon as the head was removed, there would have been sealing issues. Also, while the piston rings still had tension, they had micro cracks from the detonation which at some point would have caused them to break and likely damage the cylinder walls. The other biggie with this engine was it had galled the skirt on a couple pistons that had left aluminum deposits on the walls. These would have likely caught a piston ring and would have caused a piston to break apart. At that point, you could have a loose connecting rod which could poke holes and cause major damage.
My point in telling all of this is, IMHO only a foolish person would choose not to do a thorough disassembly & inspection after an engine has been overheated to the point of seizing. While the issues caused by the overheating may not seem significant at first, there is likely hidden damage that was caused that if discovered early can be minimal in costs.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 11-30-2021, 02:30 PM   #19
Crankster
Crankster's Avatar
Default Overheated motor
Is that where we're at now, the engine in question is siezed up?
Old 11-30-2021, 03:00 PM   #20
daren007
I am under the impression the engine overheated but did not seize. This can dry the cylinder walls but cause no other damage. I could be wrong here.
