02-08-2021, 03:24 PM | #1 |
It Was Tough But......
HI ,Guys just wanted to share this image with you.I recently read an article on how to place the stone guard inside the radiator shell. I like the idea and the look so I gave it my best shot. Here is the result, I'm very pleased , it still functions as a stone guard and i can see the blue on top and the black on the bottom. LOTS OF PATIENCE thanks for looking. THE HOOCH
02-08-2021, 03:41 PM | #2 |
Re: It Was Tough But......
Wow looks great! Good Job!
_________________________________________ 1931 Ford Model A Tudor 1930 Ford Model A Deluxe Roadster 1930 Ford Original Rolling Chassis- Restoring |
02-08-2021, 04:29 PM | #3 |
That does look good,and I'm a guy that doesn't like stone guards.It's just that I don't like them hiding the shell above and below the core.How did you get it spaced out so it isn't riding on the fins?
02-08-2021, 04:41 PM | #4 |
I really like the look of it. Sounds like it isn't easy? Did you have something to go by?
02-08-2021, 04:43 PM | #5 |
Sharp! Congrats
02-08-2021, 06:26 PM | #6 | |
And I agree, Hootch, it looks great. Really nice job. Especially with the color panel in the radiator shell. JayJay
JayJay San Francisco Bay Area ------------------------ 1930 Murray Town Sedan 1931 Briggs S/W Town Sedan |
02-08-2021, 07:12 PM | #7 |
If you don't want to cut up the stone guard sold by the parts stores you can buy just the mesh from McMaster Carr, see https://www.mcmaster.com/9656T11/.
02-08-2021, 08:29 PM | #8 |
WOW ! That looks nice!
02-08-2021, 08:35 PM | #9 |
Nice work, looks great !
Sent from my iPhone using Tapatalk |
02-09-2021, 09:21 AM | #10 |
Thanks nKaminar
I will check that out and order the piece and not have to cut my stonegard. Great Idea, I really like the look of it but took mine off as it covers up the radiator shell Thanks again |
02-09-2021, 01:22 PM | #11 |
I really favor that McMaster Carr option!
Alan 1929 Special Coupe 1941 Pick-Up 1955 Victoria |
02-10-2021, 04:12 PM | #12 |
after cutting and fiting perfict, i used a wood dowel on the outside of the shell and wired it in place both top and bottom, then used J B weld 5020 and glued it into place BOTH TOP AND BOTTOM on the inside of the shell . there is enough space for the guard to fit but cutting the top ,bottom, and sides near the top requires patience.
02-10-2021, 06:30 PM | #13 |
Check out McMaster's price for a 36x36 sheet. Maybe try some diamond mesh stucco lath and paint flat black.
