03-15-2015, 01:15 PM | #1 |
The Janitor
This part called the janitor, I'm thinking about installing one. Are they difficult to install? Do they bolt on? Thanks in advance
03-15-2015, 01:29 PM | #2 |
Re: The Janitor
Never heard of it-outside of the profession. What is it-maybe a picture?
Mike
1930 TownSedan (Briggs) 1957 Country Sedan |
03-15-2015, 01:38 PM | #3 |
Re: The Janitor
I know a lot of things; I just can't remember them all. 1928 CCPU 82-A 1931 Roadster 40-B Dlx (Canadian) |
03-15-2015, 01:43 PM | #4 |
Re: The Janitor
Mikes afordable parts has them, they bolt on. 10 min. job.
Rear Main Janitor - Diaper - Model A Ford - Buy Online! Code: A6768 Model Year: 1928 - 1931 UOM: Each Quantity in Basket:none Price: $19.95 |
03-15-2015, 01:56 PM | #5 |
Re: The Janitor
Louieglen, I have one on my Town Sedan. It was given to me when I bought the car because the PO thought it had a rear main leak. So I installed it. Turned out most of the oil was coming from the oil return pipe.
I installed it anyway but my rear main doesn't leak much. The diaper seems to work OK. I put a "feminine napkin" in it and change it once a month. Last edited by Y-Blockhead; 03-15-2015 at 01:59 PM. Reason: Punctuation |
03-15-2015, 02:18 PM | #6 |
Re: The Janitor
03-15-2015, 02:44 PM | #7 |
Re: The Janitor
It is a "snap on - snap off" installation. The holes are large enough to just snap over the bolt heads. Very simple to do and keeps any drips off the driveway.
03-15-2015, 08:26 PM | #8 |
Re: The Janitor
I have one, works great but can be tricky to remove. I put an oil drain pan under it and let it dop.
Sewall |
03-15-2015, 08:32 PM | #9 |
Re: The Janitor
it should be renamed to the
sanitation engineer i have never needed it because i am still trying to figure out whats causing my motors to not leak this has been an ongoing issue |
03-15-2015, 09:27 PM | #10 |
Re: The Janitor
to bad mitch a problem I bet, not having a leak at the main lmao.
03-16-2015, 08:05 AM | #11 |
Re: The Janitor
I've always heard that if a Model A ain't leaking, it's empty.
03-16-2015, 09:45 AM | #12 |
Re: The Janitor
I've got the same problems as Mitch//pa in post #9 above.
Janitor? Fix the problem, not the symptom. |
03-16-2015, 11:03 AM | #13 |
Re: The Janitor
It is not bolted on, just compressed over the bolt heads.
03-16-2015, 11:07 AM | #14 |
Re: The Janitor
I used the Janitor for a while, along with absorbent pads, just as a Band-Aid for the symptoms, but only until I fixed the problem. Now the janitor has it's special place on the shelf in my garage as a gentle reminder of days gone past.
03-16-2015, 05:44 PM | #15 |
Registered User
Re: The Janitor
wow
i should have patented mine back in 1970 works on rear main and rear end both,, universal fit its never failed me we used to keep one inside the car also it was for the kids as there wernt bathrooms every exit or corner worked great tom |
04-20-2015, 10:31 AM | #16 |
Re: The Janitor
I never have to empty mine. I think it dumps out on the hills.
04-20-2015, 10:50 AM | #17 | |
Re: The Janitor
04-20-2015, 10:52 AM | #18 |
Re: The Janitor
Hey Mitch, it must be contagious, not a drop here "And I don't know whyyy"
Bul I'll keep driving til I figure it out. Not that I've driven all that far yet.
04-20-2015, 10:54 AM | #19 | |
Re: The Janitor
Your crazy man, love it. Very old school
04-20-2015, 11:19 AM | #20 |
Re: The Janitor
I put a rubber stopper in mine to simplify emptying. Drove it like this for three years before getting a real fix. Gotta do whatcha gotta do.
Ray White |
