06-23-2020, 07:59 PM | #1 |
Brake Master cylinder 40
I recently purchaced a master cylinder for the 40 and I have noticed threads on the forum talking about some of these things sticking and holding the brakes depending upon where they were made.
Is there a way to bench test a unit or check it out before I install it to see if it is ok? photos? thanks in advance. |
06-23-2020, 08:06 PM | #2 |
Re: Brake Master cylinder 40
Inside ther are 2 holes, one is larger, the smaller one is the compensating port, the piston cup has or move back enough to open it to release pressure--- a small wire can be gently used as a feeler to see if piston cup exposes it---- another way is to watch for the little squirt as the pedal is pushed slowly ( don't put face over it till you have tried it to see if it sprays out)
06-23-2020, 09:26 PM | #3 | |
