04-09-2021, 12:52 PM | #35 |
Re: Engine not starting - checked everything - no more idea
I had the same thing after rebuilding the engine. Everything was OK, but it did not run !
Finally checked the camshaft timing. That was completely wrong, 10% off ! Do check the timing, cam gear dot to the right edge of the crank gear peg. Wish you luck ! Henk
You don’t own a Model A ... it owns you ! |
