Old 08-16-2020, 09:48 AM   #1
tubman
tubman's Avatar
Default Question about a "Helmet" distributor
Probably a simple question, but I'm now an 8BA guy so my knowledge of the early stuff is fading into the mists of the past.
My question is : Is there a gasket between the coil and the body of a "Helmet" distributor? If so, does anyone know about how thick it is?
Old 08-16-2020, 10:06 AM   #2
RalphM
RalphM's Avatar
Default Re: Question about a "Helmet" distributor
Yes, cork gasket, approx 1/16”.
File Type: jpg 77FF5BD4-B735-407B-ADBB-49D96D2A2D94.jpg (63.5 KB, 43 views)
RalphM is offline   Reply With Quote
Old 08-16-2020, 03:40 PM   #3
supereal
supereal's Avatar
C&G (800/266-0770) shows complete distributor gasket sets for 32 thru 47 for $7.95
supereal is offline   Reply With Quote
Old 08-16-2020, 03:44 PM   #4
supereal
supereal's Avatar
C&G offers complete distributor gasket sets 32-47, 7.95/set. (800/266-0470)
Old 08-16-2020, 03:49 PM   #5
FlatheadTed
FlatheadTed's Avatar
Just to add ,You might want regulate the thickness of that gasket depending the spring tension to points contact required ,or if your running a adapter or not ,
http://www.flatheadted.com
Flathead Ted brake Floaters ,
Old 08-16-2020, 04:28 PM   #6
Charlie ny
Denny,
Refresh my memory....address please..........six coming your way various thickness's.
Charlie ny
Old 08-16-2020, 06:08 PM   #7
tubman
tubman's Avatar
Guys, I don't need any. I just want to know the thickness so I can get the dimensions on my new '33-'36 condenser right. I have a body and a coil, but no gasket, and the way these things are put together, the gasket makes a difference on the way the ground strap fits. No matter what anybody else does, it seems nobody can make a decent condenser for these things. We want to offer them in two values, one for stock coils, and one for modern (Skip's) coils. I want to get them right the first time to keep the good reputation I think I have already earned with my "Trash Cans".
Old 08-16-2020, 08:06 PM   #8
34fordy
34fordy's Avatar
[QUOTE=tubman;1920961]
I was under the impression that a Skip coil would use the same original condenser with the .36 mfd. If not, how would you know what to use?
Good to hear that tubman is still working on this project.
34fordy is offline   Reply With Quote
Old 08-16-2020, 06:20 PM   #9
Charlie ny
Denny,
I'm guessing the goose neck bend in the strap was to accommodate various thickness's...Why not let me send you some in various thicknesses and material.
Charlie ny
Old 08-16-2020, 06:31 PM   #10
tubman
tubman's Avatar
Thanks Charlie. I think that might be a good idea. I'll PM my address.
Old 08-16-2020, 07:40 PM   #11
35fordtn
35fordtn's Avatar
Denny,
A simple suggestion....
On my cars I trim the condenser bracket into a “u” shape rather than a hole, so that I can remove the coil without having to completely remove the distributor bolt. It’s a real time saver as in some cars like a 1937-9 that bolt can be a pain to reach and easy to drop. and also helps allow for varying gasket thicknesses. The 81a condenser for 37-41’s grounds through the coil screw rather than the typical 78 type that grounds through the mounting bolt. I think I sent you a version of both as well as a 32/36
Old 08-16-2020, 09:07 PM   #12
JM 35 Sedan
JM 35 Sedan's Avatar
I use stock condensers that are tested and known to be good with Skip's rewound coils. They work well....and last a good long time.
John
Old 08-19-2020, 10:16 AM   #13
Yoyodyne
Yoyodyne's Avatar
Does 6V vs 12V make a difference in the condenser needed?
Yoyodyne is offline   Reply With Quote
Old 08-19-2020, 11:05 AM   #14
tubman
tubman's Avatar
Nope.
Old 08-19-2020, 11:45 AM   #15
philipswanson
Plain old Napa condensers work fine with Skip's coils. Many miles with zero problems.
philipswanson is offline   Reply With Quote
Old 08-19-2020, 10:41 AM   #16
Bob NH
Bob NH's Avatar
Could someone tell me how you go about testing a condenser as I have several and have no idea if they are good or not ?
Bob NH is offline   Reply With Quote
Old 08-19-2020, 11:03 AM   #17
G.M.
Search back in this forum, I put a detailed method
for testing condensers. Almost all of them test good
cold but need to be heated to over 200 degrees, hot
is when they breakdown. G.M.
www.fordcollector.com
Old 08-19-2020, 12:14 PM   #18
35fordtn
35fordtn's Avatar
There certainly are condensers out there that work .... But.... When Tubman comes out with his 32-36 Ford condensers you can sure bet I'll buy a few.
I build early distributors literally daily and test condensers daily. As GM said you have t treat them like they are on the car with heat to test them properly. Simply measuring the capacitance is not enough. The leak down rate is important as well.
Old 08-19-2020, 02:28 PM   #19
tubman
tubman's Avatar
Michael,
We are still working on this project, but are close to being done. Right now, we are optimizing our manufacturing process so the cost can come in at a reasonable level. I'll be sending you some pre-production prototypes soon.
Denny
Old 08-19-2020, 03:13 PM   #20
Yoyodyne
Yoyodyne's Avatar
Put me down for 2 for a 35-36 when they are done. No rush!
