01-21-2018, 10:04 AM | #1 |
1936 Columbia rear
I'm having a problem identifying this type rear. I found one and was told that it's for 1936. I read that the Columbia unit is on the left side of the rear but the one I located is on the right side of the rear. I'm confused. Need help with this question. How can I really know if it for a 1936. Also if it is how can I tell the size gears in it. Helpppppp!!!!
01-21-2018, 10:42 AM | #2 |
Re: 1936 Columbia rear
Post pics of what you have.Don't know where you read that but Columbia's are all on the right side.35-36 radius rods are attached a bracket on the banjo housings close to the flange for the brake backing plate, after that ('37) they attached to the flange at the backing plate end of the housings.Most gearsets were 4.11 for Banjo's.On the web of the banjo underside near where the torque tube flange are some numbers that should be stamped .That should tell you the gear ratio.
01-21-2018, 11:35 AM | #3 |
From 1942 thru 1948 they are wider by an inch and a half or so. If the tag is still on it, it should have the last two digits of the year with a prefix F for Ford, M for Mercury, or LZ for Lincoln. Parts can be mixed & matched though so there is no guarantee even with a tag. The 35 & 36 should have the bone mountings that were mentioned previously plus mechanical brakes. The 33 & 34 are very rare and the 35 & 36 are not common either. The 37 thru 41 are more common but the 42 thru 48 are the most common and are the wide ones. The wide ones will work on an older car but the wheels will stick out from the body a bit more. Some folks modify the wide ones to work on the earlier axles but it takes someone with a jig and some experience to get it right. Bullet proofing one is a good idea. Some of the parts are weak and should be reinforced before they crack. The Columbia mod can get expensive but they are really nice on a period correct car. http://www.columbiatwospeedparts.com...r-columbia.cfm
01-22-2018, 08:37 PM | #4 | |
01-22-2018, 11:00 PM | #5 |
Peter that's on good looking Columbia rear. Nice job
07-06-2018, 04:18 PM | #6 |
-------------- Drive it like you know how to fix it! DMAFC / OILERS CC-MC |
07-06-2018, 06:04 PM | #7 |
This Columbia came from a 35-36.Some one added the shock mounts.
07-06-2018, 07:50 PM | #8 |
My Columbia has a 3.78 gear and works fine on my 35
DON P |
07-06-2018, 08:11 PM | #9 |
I have a 3.54 in my '36. It runs 3000 rpm at 60 mpg. I am thinking of putting a Columbia in it so it is more road worthy but everyone says I need a 4.11 in it. That just sounds like I am defeating the purpose. If I do go with a Columbia and my 3.54, will I be lugging the engine?
07-06-2018, 08:48 PM | #10 |
With 3.54s you should be running close to 70 mph at 3000 rpm, with stock 600-16s.
07-06-2018, 10:22 PM | #11 |
'36 Columbia axle.
07-07-2018, 09:14 AM | #12 | |
With those figures, this doesn't seem to represent a 3.54:1 ratio at all. It seems more representative of a 4.11:1 ratio. A 3.78:1 should do better than those figures unless the car has smaller diameter rear tires. I'd wonder about speedometer accuracy or whether it actually even has that ratio. |
07-06-2018, 10:33 PM | #13 |
Mph X 336.1524 X final drive ratio ÷ tire diameter = RPM
07-07-2018, 09:48 AM | #14 |
This may help.
