Old 10-18-2020, 08:38 PM   #1
mgerhold
Default rear end oil
what should i use for rear differential oil in my 1953 mercury? can i use the Lucas 80w90 gear oil without any problems?
mgerhold is offline   Reply With Quote
Old 10-18-2020, 08:47 PM   #2
Clem Clement
Clem Clement's Avatar
Default Re: rear end oil
Is it GL4?
Clem Clement is offline   Reply With Quote
Old 10-18-2020, 08:54 PM   #3
mgerhold
its says it exceeds gl5. do i need to run gl4 gear oil?
Old 10-18-2020, 09:38 PM   #4
Talkwrench
Talkwrench's Avatar
No you dont in the diff.
"Came too close to dying to stop living now!"
Talkwrench is offline   Reply With Quote
Old 10-18-2020, 09:38 PM   #5
JSeery
JSeery's Avatar
Not in a rear axle, GL5 is a transmission issue, not a rear axle issue. High EP additives can attach "yellow" metals, like those found in a transmission. That should not be an issue in a rear axle.
Old 10-19-2020, 09:56 PM   #6
mgerhold
ok so using the Lucas 80w90 gear oil in the rear axle should be fine. just wanted to make sure.
