09-01-2020, 10:49 AM | #21 |
Re: Ford rims ?? Wide
The pic that Lanny posted of a wide 5 wheel, is not a Ford '36-39 artillery type wheel, no 'spokes', it is a slotted wheel.
Marmon-Harrington used the wide 5 bolt pattern on their 1/2 ton 4x's through '48. I know where there is a '48 Ford M-H Deluxe coupe in Montana that has the 10" wide 5 bolt pattern. The car was bought new by the family that still has the car. I can't say if the wheels on the MH are spoked or slotted, I've only seen the car twice. Somewhere in my albums I have a pic of the car.
Bill.... 36 5 win cpe |
09-01-2020, 12:41 PM | #22 |
FWIW the wide 5 pattern is 10-1/4". I thought it was 10" and had a plate made at work so I could balance them. It's embarrassing having to go back and ask them to redrill it when it was done as a favour in the first place...
Mart. |
09-01-2020, 01:43 PM | #23 |
Yup...10.25"! DD
09-01-2020, 02:10 PM | #24 |
These wide 5 wheels measure 10" center to center of any 2 holes
furthest apart from each other, but if you measure that bolt circle correctly, then that is a 10.25" bolt circle. .
If mama ain't happy, ain't nobody happy. But if daddy ain't happy...RUN |
09-02-2020, 01:49 AM | #25 |
Here is a 16X5 wide 5 ,5" wide listed.I have seen them 5.5 " and 6 " also.
EBAY item number,274480055379 Last edited by deuce lover; 09-02-2020 at 01:55 AM. |
09-03-2020, 11:25 AM | #26 | |
. This wheel listed on ebay is only 60 miles north of me. I'm Not going to be using my wheel in post 15 here, so if anyone needs a couple 16x5's,,,here ya go. .
09-03-2020, 11:41 AM | #27 |
09-07-2020, 08:04 PM | #28 |
For what its worth, this is my rear tires seen in the middle photo is the lines where The 2 was added Outside to make a 6 wheel. Adequate for a 700 I think, test mounted on the 4 and it looked like a bicycle tire, so opted for adding space, will do it over for the next car.
