04-17-2020, 06:31 AM | #1 |
Flathead Friday: 33 coupe motor pull. Crusty head swap.
Hello. Welcome to yet another scintillating video from Mart's Garage. It's time to bite the bullet and yank the motor out of my 1933 Ford 5 window coupe. It's going to get the Crusty Flatty. I got the new heads for the Crusty Flatty from my mate Glen. Many thanks Glen. I put them on but do a clearance check first, as they had been skimmed.
Once again, this was plagued by technical problems, including first of all a complete microphone failure, then a unsatisfactory fix. I lost a lot of footage on the motor teardown and radiator removal. I did the best I could with what I had. You can use the closed captions on the part where the audio volume is low. They kinda work. I'm trying to build the channel so please subscribe, and leave a comment. Thanks to everyone who has been following the Crusty Flatty saga. Mart. Here's the link, but can you please click the icon to watch it in YouTube so the like and subscribe buttons are available. Thanks: https://youtu.be/y3p6hfrLH4Q |
04-17-2020, 09:52 AM | #2 |
Re: Flathead Friday: 33 coupe motor pull. Crusty head swap.
Mart
I always mill my head to give .045/.050" piston to head clearance. This doesn't raise the CR very much, but causes a high degree of turbulance in the chamber, by increasing the "Squich" areas. I measure the clearance by using small alum balls made from alum foil and stuck on the pisto and valve with alittle grease. It's more accurate than clay.. If the piston is hitting the head you can increase the clearance with a dremmel tool. The end result is better throttle response an economy. |
04-17-2020, 09:59 AM | #3 |
Hi Ron, glad you took the time to watch my video. I always heed your advice. I do not have a mill big enough to skim my heads. If I did have, I'd be doing exactly what you've been preaching. With these red ones, I just had to use them, so it was a case of like it or lump it. I guess some sort of skim is better than no skim, though.
Cheers. Mart. |
04-17-2020, 01:12 PM | #4 |
Jonathan W watching... you've hit the big time! 8^)
"whatever works!" |
04-18-2020, 05:21 AM | #5 |
Yeah it's like YouTube royalty.
04-19-2020, 08:02 AM | #6 |
I'm thinkin' about crankin' My ragged ol' truck up and haulin' myself into town. Billy Joe Shaver |
04-19-2020, 08:13 AM | #7 |
Mart, what wa wrong with the first heads i watched you install ?
Can't wait to hear it run. mike |
04-19-2020, 08:35 AM | #8 |
I wanted to leave the other engine relatively intact. Plus that crank had a repair done back in the day and it is non stock where the pulley bolts on.
The green heads had some heavy pitting in one of the combustion chambers. Mart. |
04-19-2020, 10:08 AM | #9 |
Mart, a nice little video of your entire garage would be interesting. Always fun to check out other people's junk.
04-19-2020, 10:48 AM | #10 |
good idea russ! i saw that 32 again, its a 5w, dont know why i was thinking roadster. mart, she'll look pretty with those sexy red heads
04-20-2020, 11:21 AM | #11 |
The 32 body in the corner is a 2 door sedan. Who knows? I might get around to getting it built one day.
04-20-2020, 11:37 AM | #12 |
As far as “A’s” and “32’s” go, I think the Tudor Sedans are the best body style. Where I live you need a roof and a heater ten months a year and the extra room would be handy...Mark
