11-07-2016, 11:16 AM | #1 |
Removing the "tempered" etching from glass
I had a rear window glass made for my pickup and had it tempered. Unfortunately the glass tempering place etched a label on the lower corner of the glass. The fingerprints and smears around the etching is not a problem, just the etched lettering. I don't want the etching on the glass. Maybe they have to do it by law. Does anyone know how to remove the etching - some compound? If the glass is slightly wavy after the etching is removed, that's OK.
Thanks for any advice. Rusty Nelson |
11-07-2016, 11:20 AM | #2 |
Re: Removing the "tempered" etching from glass
How large is it ? Many people pay to have that symbol engraved. Wayne
11-07-2016, 11:48 AM | #3 |
I bought both of my front door windows from Bert's and they are tempered but don't have an etching. I don't know if it is required or not.
11-07-2016, 12:08 PM | #4 |
I'M not sure about your state, but in California you have you glass labeled.
There is a requirement that all vehicle glass be a safety glass of some kind. That label is your proof. I California a glass shop is required by law to install safety glass, with the label showing. Granted it's not something that is checked very often, until you end up in court. Just a late after thought, maybe if the laminates are visible you don't need a label??
Connoisseur of Rust Last edited by Jerry in Shasta; 11-07-2016 at 12:19 PM. |
11-07-2016, 12:16 PM | #5 |
Y blockhead,,,, Maybe the label is not required in CO. Just as a thought keep Berts invoice just in case.
Connoisseur of Rust |
11-07-2016, 12:25 PM | #6 |
11-07-2016, 01:08 PM | #7 |
Y blockhead, call a local glass shop they will the requirements.
JB
11-07-2016, 01:41 PM | #8 |
Jerry, PM sent. I didn't want to hi-jack Rusty's thread.
11-07-2016, 02:42 PM | #9 |
You always tell them it is for a picture frame.
If it is car glass it needs to be marked. Least that was what I was told once. |
11-07-2016, 03:05 PM | #10 |
Rusty, if the etching was done with acid, try some clear nail polish over the area. A very light coat. Maybe even dilute the clear lacquer with some thinner so that it flows easily into just the etching. That might make it disappear or be much less noticeable.
11-07-2016, 05:48 PM | #11 |
You may be able to remove some or most of it with cerium oxide, water, and a felt pad.
Technically, DOT requires safety glass in all vehicles and the glass to be marked with a visible DOT number (identifying the manufacturer of the part). Most flat glass tempering plants are not "certified" to mark the glass with a DOT number and will mark it with an architectural certification. Most tempering plants will produce tempered glass with "no logo" if you ask. Some plants are sticklers and put a logo on all their glass. In your case, once you remove the logo, chances are very slim you will have a problem with the "Law". However, there is no logo to prove it is tempered if needed for car club tours, events, or shows. Hope this helps. Phred, Herb's Glass, Elgin IL |
11-07-2016, 06:31 PM | #12 |
Location: Barren windswept mountain somewhere in bleak Northeastern Pennsylvania
Around here, we're just happy to have un-busted, non-fogged glass in the A Model Ford windows. The windshield in our rambling wreck 31' Tudor sedan has a logo with a 1942 date on it. Put the WW2 "B" gasoline ration sticker right near the period windshield etching. We're all set to car pool the gang for the daily trip down to the war plant to build them bombers. Keep em' flying!
I wouldn't be so paranoid if people weren't plotting against me all the time |
11-07-2016, 06:34 PM | #13 |
why not just go to a glass shop and let them do their work. Wayne
11-07-2016, 08:07 PM | #14 |
Thanks for the responses. I might try some cerium oxide paste (thanks Phred) a see if it reduces the etching.
Rusty Nelson |
