04-02-2015, 02:08 PM | #1 |
cross shaft bshings
hello-i bought some nylon bushings for the rt and left ends of the cross shaft. should there be some slop between the in. diam of bushing and out diam. of shaft. ? shaft does not seem to be worn. what is the minimum o.d. of shaft at which the shaft must be replaced? thanks
04-02-2015, 03:28 PM | #2 |
Re: cross shaft bshings
I was unaware that anyone manufactured those in Nylon. That does not seem like it would be substantial enough to keep from flexing during firm braking. As for a way to tell if your shaft area is worn, look at the shaft size either next to, --or under the arm as this was the original size.
04-02-2015, 06:49 PM | #3 |
We have made them for 30 years out of UHMW, and they work very good, as long as the shaft is not worn too much.
Steve Becker Berts Model A Center |
04-02-2015, 07:10 PM | #4 |
You can also use the split bushings. They work well on a shaft that has some wear. Use a liberal amount of grease when installing. They will compress within the clamp for a good fit.
04-03-2015, 08:52 AM | #5 |
Ditto Dick M. Split the bushings = cut them in half with a hacksaw. No precision is necessary as long as you keep the matching cut halves together. Put some synthetic grease on the shaft.
Bob Bidonde |
04-04-2015, 07:13 AM | #6 |
