Old 06-08-2013, 09:04 PM   #1
glenn in camino
glenn in camino's Avatar
Default oil pump shield
Where can I get an oil pump shield for my full pressure B engine
glenn in camino is offline   Reply With Quote
Old 06-08-2013, 09:18 PM   #2
pat in Santa Cruz
pat in Santa Cruz's Avatar
Default Re: oil pump shield
Snyders has it in their catalog listed as for a 31, but I think they fit a B engine as well. The pumps are the same size, even though the inside shaft differs
pat in Santa Cruz is offline   Reply With Quote
Old 06-08-2013, 09:21 PM   #3
CarlG
CarlG's Avatar
Snyders Part # A-6631
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 07-26-2020, 09:03 PM   #4
duke36
So has the shield been used successfully with the pre late 1931 oil pans by trimming the shield bottom ? It appears the oil pump holds it up to the block. If the gasket is used, where is it placed? Are any other mod's to the oil pump required ?
duke36 is offline   Reply With Quote
Old 07-27-2020, 03:41 AM   #5
john charlton
john charlton's Avatar
No mods to the oil pump . No gasket required .Years ago in my innocents I fitted the shield from a "B" engine into a "A" engine with no apparent ill effects .I recently pulled the pan off this engine and removed the shield . No damage/buckling was found . Could be the shield was for an "A" engine anyway . Someone on the site must know the different skirt length between "A" and "B" hope they chime in .
John in light cool rainy morning in Suffolk County England .
john charlton is offline   Reply With Quote
Old 07-27-2020, 04:43 AM   #6
john charlton
Thinking about it I now think the shield is the same and the detents for the dipper tray was dropped a bit when the shield was introduced I must check the "Service Bulletins"
John in same place same weather .
Old 07-27-2020, 04:50 AM   #7
DBSHELTON
Model A Medic sells one that works with the standard Model A Dipper Tray. Easy fit. I have used several.
DBSHELTON is offline   Reply With Quote
Old 07-27-2020, 07:36 AM   #8
Benson
Benson's Avatar
Yes John, page 576
The detent on the dipper tray was raised 1/8 inch, which lowers the tray itself.
Kinda sounds like they were worried about the shield hitting the tray maybe Huh?
I wonder if they found the shield hitting the tray and vibrating?
The bulletin also says NEVER INSTALL shield without the new tray.
Benson is offline   Reply With Quote
Old 07-27-2020, 08:06 AM   #9
denis4x4
denis4x4's Avatar
PM me as I have an original one for sale from a B engine.
No restorable Model A's were harmed in the building of this truck!
denis4x4 is offline   Reply With Quote
Old 07-27-2020, 08:48 AM   #10
Benson
Benson's Avatar
Surely Glen has found a shield in the last 7 years but I am not sure that a shield is needed on a B engine with pressurized rod bearings as the dipper tray has no dippers needing to pick up oil for rods.
Old 07-27-2020, 09:58 AM   #11
katy
katy's Avatar
So what is that shield actually supposed to do?
Old 07-27-2020, 10:36 AM   #12
duke36
Where does the A6626 gasket go ? Against the oil pump or above shield to block, if that makes sense? Also, if ones installs the accessory valve cover oil filter, are there any adverse effects with the shield?
Old 07-27-2020, 12:14 PM   #13
Tom Endy
Tom Endy's Avatar
Attached article about oil pump shield.
Tom Endy
Tom Endy is offline   Reply With Quote
Old 07-27-2020, 12:43 PM   #14
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
That is the Oil Pump Screen Cover Gasket. It goes between the metal Screen Cover and the A-6604 Oil Pump Body.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 07-27-2020, 03:48 PM   #15
duke36
OK; Bratton's must be a typo if reading it wrong ? It says "on top of the
cover". No other gasket needed except the gear cover gasket on the bottom of the pump and nothing extra for the shield.
So the pump body is the only thing holding the shield up into the block, and trimming it to fit an older tray shouldn't be a problem unless the repro shields have folded metal bottoms. I haven't been able to understand from other threads whether there is an adverse reason if the tray should be lower in the pan other than for shield fitment and/ or it affects the splash system lowered an additional 1/8". Evidently the engineers didn't think so?
Old 07-28-2020, 11:54 AM   #16
Jim Brierley
On a full-pressure system the most important thing is to baffle the oil so it doesn't run away from the pump on acceleration, deceleration or hard right turns. On some of my engines I don't even run the dipper tray, just baffles that I have installed in the pan itself.
Jim Brierley is offline   Reply With Quote
Old 07-28-2020, 12:05 PM   #17
Jack Shaft
glen passed last year..he doesn't need a shield..hopefully
Jack Shaft is offline   Reply With Quote
