Old 09-02-2020, 07:41 PM   #1
dlfrisch
dlfrisch's Avatar
Default Steering arm knuckles
I would like to ask......How tight or what are the steering arm end knuckle fittings specifications to be properly adjusted (where they are greased) ?
dlfrisch is offline   Reply With Quote
Old 09-03-2020, 08:23 AM   #2
1931 flamingo
1931 flamingo's Avatar
Default Re: Steering arm knuckles
Are you talking King Pins??
Paul in CT
1931 flamingo is online now   Reply With Quote
Old 09-03-2020, 08:24 AM   #3
ryanheacox
ryanheacox's Avatar
I don't have an actual spec but a good rule of thumb with all new parts (including round balls on the ends of the arms) is to tighten the plugs until they are flush with the opening and then just enough to line up the cotter pin hole.
I think I did read that you want 25% spring compression somewhere, how you measure that easily is beyond me.
Old 09-03-2020, 09:48 AM   #4
1930-Pickup
This is easier if you have a caliper, but a ruler will be okay.
1. Measure the overall length of the spring.
2. Measured Length x .25 = Distance To Compress.
3. Grease parts as needed.
4. Install spring, and cup, and plug.
5. Screw plug in until all loose slop is gone.
6. Screw the plug in the Distance To Compress.
"That's my wild unsubstantiated guess, and I'm sticking to it regardless of the facts!"
1930-Pickup is offline   Reply With Quote
Old 09-03-2020, 11:19 AM   #5
dlfrisch
dlfrisch's Avatar
No, not the king pins.......looking at the cross bar.....and the other knuckle / grease areas. How tight should they be?
Old 09-03-2020, 04:08 PM   #6
Mad Mac
In my case, with rather worn balls on the drop-arm and drag link, I had to screw them in really tight before I reduced the "wandering" tendency on the road. Might be different if the balls were not worn.
Mad Mac is offline   Reply With Quote
Old 09-04-2020, 11:34 PM   #7
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
They’re called the tie rod and tie rod ends.
Old 09-05-2020, 06:23 AM   #8
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
...actually they're called the 'Spindle connecting rod tube' and 'Spindle connecting rod ends'.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
