Old 08-29-2020, 03:47 PM   #1
gotcat267
Default Ford rims ?? Wide
Was wondering if anyone might know what these rims came off of and what year range .thanks
gotcat267 is offline   Reply With Quote
Old 08-29-2020, 04:10 PM   #2
V8COOPMAN
V8COOPMAN's Avatar
Default Re: Ford rims ?? Wide
'36 thru '39 Ford wheel. Welcome to FordBarn! DD
Click Links Below __
T5 W/TORQUE TUBE
Old 08-29-2020, 04:26 PM   #3
gotcat267
Hey thank you I appreciate it !
Old 08-29-2020, 04:27 PM   #4
gotcat267
Do you know which size radials will fit it ? Currently has 6.50x16
Old 08-29-2020, 04:28 PM   #5
alanwoodieman
could be the wheels off a 3/4 and 1 ton truck from 1937 to 47
Old 08-29-2020, 04:49 PM   #6
51504bat
51504bat's Avatar
My '39 p/u with wide fives has 215/70R16's. Another option is 215/85R16's which are a bit narrower than the 70 series I have on my p/u.
Old 08-29-2020, 06:25 PM   #7
Rodrelic
Far as I know, 60hp car 3.5 width, most cars 4”, pickup and Mercury 4.5”
I had some widened 2”, to fit 750 tires
Rodrelic is offline   Reply With Quote
Old 08-29-2020, 07:28 PM   #8
raybee
Not truck wide wheels.
raybee is offline   Reply With Quote
Old 08-29-2020, 08:28 PM   #9
Rodrelic
My 1 ton as I remember has a 7.5” 6 lug Split rim,
The picture with 650 tire probably the rim is the max for wide 5 Stock, 4.5”width
Research I had done,
I believe the 3/4 ton pickup has extra leaves, still wide 5 pattern 4.5”
4” wheel used 600 tire
3.5” used 550 tire
Old 08-29-2020, 09:13 PM   #10
V8COOPMAN
V8COOPMAN's Avatar
Guys....It's obvious that this is NOT an original tire on this wheel. People 'up-sized' tires all the time. A 6.50 tire on a 4" wheel was a normal occurrence. '36 thru '39 'wide-five' wheels were all 4"-wide except for the very few 3-1/2" V8-60 wheels that were produced. Even with no pressure in this tire, if you'll pay attention to the tire/rim between 8 o'clock and 4 o'clock, it's easy to see that this is the regular ol' narrow, 4" wheel. Heck, the second picture shows a big ol' 7.50-R16 that we put on a 16 X 4-1/2" Ford wheel. It's been done to death! DD
T5 W/TORQUE TUBE
Old 08-30-2020, 11:04 AM   #11
blucar
blucar's Avatar
The majority of the wide five wheels will have the date/manufacture, Ford or KH with month/year stamped into the back side of the bead area, generally at 6 o-clock from the valve stem.
I would doubt very much that there are very many Standard Series 16 x 3.5 wheels exist now. The 550 x 16 tire would have been an odd tire size in '36, most people would have opted for the 600 x 16 tire
Bill.... 36 5 win cpe
blucar is offline   Reply With Quote
Old 08-30-2020, 03:40 PM   #12
V8COOPMAN
V8COOPMAN's Avatar
Like I noted earlier, the 16 X 3-1/2" wheel only came on V8-60 cars. There were NO 60-horse engines in 1936. '37 was the first V8-60 here in the States. Pictured is one of the 3-1/2" wheels from 1940, which in fact, was NOT a wide-five. DD
T5 W/TORQUE TUBE
Old 08-31-2020, 10:41 AM   #13
blucar
blucar's Avatar
According to the EFV8 Club, 35-36 book, Wheels And Tires: "In July of 1936, standard model cars were equipped with 5.50 x 16 four ply non-script tires and the rim was reduced from 4 inches wide to 3 1/2 inches wide".
Old 08-31-2020, 12:13 PM   #14
deuce lover
deuce lover's Avatar
I had a 36 std 5W a few years back and all the 5 wheels which were original to the car were 3.5" wide.
Old 08-31-2020, 06:01 PM   #15
Lanny
Lanny's Avatar
Here is a 16 x 5" Kelsey wide five wheel that I have. I believe it's
from a '41 pickup, 3/4 or 1 ton...
Click on pix to Enlarge
If mama ain't happy, ain't nobody happy.
But if daddy ain't happy...RUN
Lanny is offline   Reply With Quote
Old 08-31-2020, 07:16 PM   #16
V8COOPMAN
V8COOPMAN's Avatar
Like a skunk in the wind, it's coming back to me now. You ARE correct in that those last few production '36 Standards had the skinny wheels. DD
T5 W/TORQUE TUBE
Old 08-31-2020, 08:46 PM   #17
51504bat
51504bat's Avatar
Not 1 ton. Photo shows a '38 1 ton. The wheels are 5 lug and not wide 5.
Old 08-31-2020, 10:47 PM   #18
cas3
favorite stock car racer wheels, what Lanny shows
Old 09-01-2020, 09:42 AM   #19
JM 35 Sedan
JM 35 Sedan's Avatar
You guys are correct on 3-1/2" wide, wide 5 bolt pattern wheels in '36, and these wheels are not that difficult to find today. Fact of the matter is, many people would trip over them and still not realize what they are. I've had two of these in my collection for years, and just picked up three more in a group of parts recently purchased.
The really difficult versions to find are the 1940 3-1/2" wide with 5 on 5-1/2 bolt pattern. I had two of these and sold them at relatively high dollars.
John
Old 09-01-2020, 10:35 AM   #20
blucar
blucar's Avatar
I wonder? Were the '37-39 Lincoln wheels wide 5 on 10".. If they are I would make book that the Lincoln wheels are wider than the Ford. A comment was made earlier in this thread that the Merc wheels in 39 were 4.5".
