Go Back   The Ford Barn > The Archives > Early V8
Old 03-23-2005, 02:23 PM   #1
Guest
Posts: n/a
Default block
I tore down a flathead and ran a tap throu the block headbolts. Did i ruin it. I did not know this was a no no. Can i correct it.
Old 03-23-2005, 04:17 PM   #2
Guest
Posts: n/a
Default Re: block
If that screws up a block then I've screwed up a lot of blocks. I always do it.
Old 03-23-2005, 05:00 PM   #3
Guest
Posts: n/a
Default Re: block
Running a tap through them probably wont hurt. The stock studs and holes have a stronger rolled thread, not a sharp edged thread from a tap & die.
Old 03-23-2005, 05:51 PM   #4
Guest
Posts: n/a
Default Re: block
Didn't hurt mine either.
r_
Old 03-24-2005, 01:39 PM   #5
Guest
Posts: n/a
Default Re: block
no problem when i did mine
Old 03-25-2005, 06:01 AM   #6
Guest
Posts: n/a
Default Re: block
I think you have a much better chance of getting a good seal with CLEAN holes and a good sealer. Frank
