Old 12-05-2021, 03:21 PM   #1
kirkf
kirkf's Avatar
Default 8BA in a 1940 Pickup
I have a 1940 Ford Pickup with no motor, and I have a spare 8BA.
What will be required to use the 8BA (with original 3 speed transmission)?
Can the 8BA fan be used or do you have to switch to an electric fan?
Any advice from those who have done this would be welcome.
Thanx,
Kirk
1953 Ford F100
1950 Ford F47 (F1)
1940 Ford Pickup
kirkf is offline   Reply With Quote
Old 12-05-2021, 04:33 PM   #2
Shampipple
Shampipple's Avatar
Default Re: 8BA in a 1940 Pickup
I’m in process on putting one in a 39.
Which is a little different.
To the best of my knowledge if you’re using the original torque tube rear end- you’ll need a ford truck or mercury bell housing to adapt your 8ba to the earlier style trans.
You’ll need a 40-48 style transmission assuming you have a column shifted truck.
Truck water pumps for the front mounts, or merc pumps with spacers.
Radiator inlet/outlet size is different but easy to overcome.
Best of luck.
29 Model A Roadster, 39 Pickup, 50 Custom Tudor, 66 Mustang Fastback, 79 F350, 02 Thunderbird
Shampipple is offline   Reply With Quote
Old 12-05-2021, 04:53 PM   #3
38 coupe
38 coupe's Avatar
Basically you want the exterior of the 8BA dressed out like an F-1 engine: wide belt truck water pumps, matching crank pulley and generator, truck bell housing and 10" clutch. It will more-or-less bolt in at that point. You will have to determine if the F-1 fan can be hung low enough and have enough clearance to work for you, my memory is dad had a 40 pickup set up that way back in the 80s and it ran cool.
Old 12-05-2021, 05:01 PM   #4
Shampipple
Shampipple's Avatar
Oh. And a different flywheel, and a truck oil pan if I’m not mistaken.
Old 12-05-2021, 08:34 PM   #5
Charlie ny
Keep things clean....mount the fan on the crank. Fairly easy to rework the '40 fan mount pulley to be at home on the 8BA. Quite a few posts in the past here on the barn.
Charlie ny
Charlie ny is offline   Reply With Quote
