Old 09-14-2021, 12:15 PM   #1
jtminor
Default Speed bleeders for 1949 F1
just getting ready to bleed my brake lines, I would appreciate any input for using Speed Bleeder for this project.
Or other alternatives would be helpful.
First time doing this process......
1949 Ford F1
jtminor is offline   Reply With Quote
Old 09-14-2021, 03:08 PM   #2
51 MERC-CT
51 MERC-CT's Avatar
Default Re: Speed bleeders for 1949 F1
The only "speed bleeder" I am familiar with are 'Speed bleeders' which replace the (4) bleeders with a new design bleeder that allows one person to bleed the brakes using the pedal.
They work great.
Old 09-14-2021, 06:20 PM   #3
Ross F-1
Ross F-1's Avatar
If you have replaced your wheel cylinders, check the bleeder screw threads carefully. Mine are metric. :-(
'52 F-1, EAB flathead
Ross F-1 is offline   Reply With Quote
Old 09-14-2021, 06:51 PM   #4
Shoovel
Shoovel's Avatar
I installed the speed bleeders on my 39 Coupe. They work great. I purchased mine direct from Speed Bleeders.
Shoovel is offline   Reply With Quote
Old 09-14-2021, 08:23 PM   #5
1948F-1Pickup
1948F-1Pickup's Avatar
I have them on my 48. They’re the only way to go in my opinion. Makes bleeding brakes literally painless and quick. Not to mention a one person job.
1948F-1Pickup is offline   Reply With Quote
Old 09-14-2021, 11:28 PM   #6
Phil Gillespie
Phil Gillespie's Avatar
Looking to purchase a set. Can a part No be supplied or the specs ie 3/8" x 24 x 1/1/2"?
Thanks Phil NZ
Phil Gillespie is offline   Reply With Quote
Old 09-15-2021, 12:23 AM   #7
my4dv8
No PN , but repco and super cheap sell the one man bleeder kit .As i imagine do Napa and autozone and O’Reilly’s Works like a charm . Mechpro one man bleeder kit. No need to change the wheel cylinder bleeders ,i dont profess to know the “speed bleeders”. Mechpro is Kinda like a hollow golf tee and a bottle with a magnet . never had it fail on my own ,over numerous cars bled .
my4dv8 is offline   Reply With Quote
Old 09-15-2021, 07:59 AM   #8
tubman
tubman's Avatar
Another vote for "Speed Bleeders".
Old 09-15-2021, 08:27 AM   #9
19Fordy
19Fordy's Avatar
jtminor: This thread will answer your questions.
https://www.fordbarn.com/forum/showt...speed+bleeders
Old 09-15-2021, 08:30 AM   #10
Merc Cruzer
Merc Cruzer's Avatar
They work great on my 53' Merc. Makes me wish I had done it years ago.
Merc Cruzer is offline   Reply With Quote
Old 09-15-2021, 02:09 PM   #11
jtminor
Started to bleed brakes today, two guys method. Back brakes worked fine, no luck on the front. Front brakes only - new brake cylinders and shoes, re-surfaced drums. Nothing but air coming out of front when we tried to bleed.... what did I do wrong or what's happening, you guys will know..... Thanks
Old 09-15-2021, 03:06 PM   #12
jayvee34
jayvee34's Avatar
Check fluid in master cylinder, could be drawing air if fluid is to low. Also check all your
connections for loose screws or flare nuts, and faulty flex hose.
IN GOD WE TRUST - SEMPER FIDELIS
John
jayvee34 is offline   Reply With Quote
Old 09-15-2021, 04:26 PM   #13
jtminor
Having trouble determining how to fill MC I removed the top nut, do you have to remove the square nut also ?
Old 09-15-2021, 04:36 PM   #14
Phil Gillespie
Yes you do need to remove the square nut to refill the MC. When filling allow a small air space at top of MC to allow for expansion.
Phil NZ
Old 09-15-2021, 04:41 PM   #15
jtminor
Do you remove square nut from under the truck....?
Old 09-15-2021, 05:34 PM   #16
JSeery
JSeery's Avatar
And you need to start over on the brake bleeding as there will be air in the lines. No way you can possibly bleed brakes without constantly checking the MC fluid level.
Old 09-15-2021, 05:46 PM   #17
jtminor
any clue how to remove the square nut....? having trouble getting at it....thanks
Old 09-15-2021, 05:50 PM   #18
jtminor
Any suggestion how to remove the square nut, I'm having trouble getting at it....
Old 09-15-2021, 06:14 PM   #19
51 MERC-CT
51 MERC-CT's Avatar
If you have access to the fluid chamber thru the hole left after the hex bolt/plug is removed you can fill it thru there, you do not have to remove the squared cap/cover.
Old 09-15-2021, 06:40 PM   #20
jtminor
Thanks , I will fill via that opening.....
